Lowering down to lowest level over time = leak
Giving the LR air fart and levelling height after exiting car = normal
Many YouTube videos on finding and resolving EAS system leaks.
My D4 (170,000 km on the clock) lowers soon after its parked - does that indicate an upcoming issue with its suspension?
What perth disco said and
Offsets may be out of calibration, can be adjusted with a gapiid or rovacom (flame suit already on fellas), tip is park it, measure height from 12o clock in wheel arch to floor at each corner, should be the same. If not you need to adjuat the offsets.
Car will self level as soon as it stops, except when it knows it has a trailer connected of course
I thought D4s dropped to access height when shut down unless this function was disabled in the system - or am I thinking of later models.
