Results 1 to 10 of 13
Thread: TDV8 3.6L - Penrite HPR Diesel 5 Engine Oil 5W-40
    Feb 2019
    Anyone else using this oil in their rig? It seems to be doing the job, not expensive and comes on sale from time to time at SCA.
    I've used it the last two oil changes and curious what others are using and viscosity. We're arrive 270k's and in Queensland, so doesn't get that cold.
    M
    Sep 2012
    Adelaide Hills
    yes no issues.
    if this wasnt available, what else would u use?
    Current Cars:
    2013 E3 Maloo, 350kw
    2008 RRS, TDV8
    1995 VS Clubsport
    Previous Cars:
    2008 ML63, V8
    2002 VY SS Ute, 300kw
    2002 Disco 2, LS1 conversion
    Feb 2019
    I think the Indi that used to service it was using another Penrite available to workshops. Think it was a 5w30. But it's not available to retail customers.
    Despite SCA recommending the oil in the thread title, the Penrite oil selector app recommends their "Full Synthetic 5W30" sold as Vantage Full Synthetic 5W-30 in Repco retail stores ..."compatible with Ford specifications WSS M2C912-A, WSS M2C913-A/B/C/D"
    Brisbane, Queensland
    These are the two oils I have been using.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    I also use these or something similar from cost effective maintenance. Our tdv8 3.6 has had an oil change every 10,000km, and now has over 290,000km. The motor is very smooth and quiet.
    REMLR # 137
    Feb 2019
    Thanks Pete. Nulon also have a "diesel engines" range in the same viscosity. I have never used any of their oils before.
    I know the topic of oils has come up in the past, but products change over time. Castrol magnatec professional was often discussed, but difficult to get.
    Kingston, Tassie, OZ.
    A Penrite C4 in 5w30 Enviro+ is what we use in these, and what i put in mine. A bit over spec as we don't have a DPF however that isn't an issue, and price is ok.
    May 2003
    On The Road
    would any of this change with the ( NOT SD) 4.4?
    Mar 2007
    Fuchs
    TITAN Supersyn F Eco-DT SAE 5W-30
    Part No : 4496 Ultra high performance, extreme fuel-economy engine oil especially suitable for Ford DuraTorq-Diesel engines. Optimum cold starting and lower oil consumption.
    Service Refill Capacity: 9.5* Litres
    Same oil for the 4.4 TdV8
    I get OEM Filters ( German filters) and oil from Burston's at great prices compared to the others !
    Laurie
    Why, have you finally bought one??❤
