Results 1 to 3 of 3
Thread: What is this wire? Rear of 300tdi engine
    Apr 2018
    Victoria
    Hi all
    Replacing the engine breather-to-air intake hose and this plastic wire connection attached to the hose clamp broke away from the rear of the engine.
    The wires disappear into looms so not easy to trace. It’s placement against the engine would suggest it’s a temp sensor?
    How important is it to sit hard against the engine? I was thinking of cable tying it back to the hose clamp rather than replacing.
    Thanks in advance
    - Dave
    Kingston, Tassie, OZ.
    That's the starter solenoid wire connector. I bet it won't start without that connected.
    Apr 2018
    Victoria
    Thanks mate, wire is still connected, just the plastic has broken away from the bracket.
    Good to know what it is,
