Results 1 to 10 of 16
Thread: Triton Workcentre
    Mar 2010
    Queensland
    12.97 MB
    Triton Workcentre
    Hello All,
    Do many members on the forum regularly use a Triton Workcentre? Or are they something like electric breadmakers? Initially lots of enthusiastic use. Then after a short while they are put away to collect dust.
    I have noticed that there are quite a number for sale second-hand on Gum Tree and eBay. A couple of people are also selling spare parts for old units.
    Do you consider that the Workcentres are value for money and worthwhile to have in your shed?
    How do you rate the Workcentre 2000 model?
    Are extra things like the router & jigsaw table worthwhile?
    Would it be more economical to build your own extension slide for the table saw? Just these extensions alone can be close to $500 - plenty of steel or aluminium pipe can be bought for that amount and be able to DIY.
    Kind regards
    Lionel
    Narre Warren South
    I have a Triton 2000, Triton saw, extension table, dust collector and the router table (with a GMC router). Oh and there are the multi-stands, finger jointer attachment and I picked up a 'super-jaws' at a Trash & Treasure market a while back.
    Was used a lot, then I joined a woodwork club and have access to much bigger equipment for $70 per year. The Triton gear gets dusted off every now and then when I can't get to the club.
    Great if you want to use it at a different location as they fold down for transport.
    I think a lot of people purchased Tritons when they were either building a house or retiring. They come up for sale because they are no longer used or the owner has purchased something more heavy duty.
    George Lewin sold out to Hills Industries then it went to GMC just before their collapse then I think it changed hands again and is now made in the UK ?
    Multi Stands are handy working on Land Rovers.
    DSCF2424 by Colin Radley, on Flickr
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Torres Straits
    Across three generations we have four tritons.
    Of course they are scattered about the country and when needing to rip a length of timber to fix a table the other day the closest was 800km away
    dad and I came up with this multi functional saw table
    Getter done
    Steve
    Ps excuse upside downness
    I've got one that used to be my dad's.
    Has my 9" Makita saw living in it (you don't want to be putting the saw in it every time you want to use it, PITA) and only gets used for ripping timber. I put locking casters on the legs so it's a breeze to move around.
    I'll end up buying a table saw with larger capacity at some stage that will connect to the Seppach dust extractor I already have.
    All the router stuff I do is 'freehand', i.e. the work is clamped and the tool is mobile, even 50m of treated pine quad section to match 1860 original. I'm just used to doing it that way.
    Your decision depends on how many functions you want to do, how serious the work is (i.e. you can only rip to about 70mm from memory using a 9" saw, the biggest that will fit as stock.
    cheers, DL
    Aug 2010
    Sunbury, VIC
    FIL has one and it sees regular use - I use it almost every time I’m down there and keep thinking U should get one, but I don’t have the room really. Good bit of kit IMO.
    Bunbury, WA
    I've got the 2000 model. Saw and router tables. I do mostly metal based work nowdays but they do get a go every so often. The last project was cutting some perspex for the S1 windows.
    They're good for what they are, i.e. home handyman quality tools.
    Apr 2019
    Koojan WA (part time Perth)
    Quote Originally Posted by cjc_td5 View Post
    But it get you out of the **** sometimes
    I always seen my old boy gin around for ages every time he wanted to cut a bit of timber to size, one of the first things I did when I was 17 was go down to the big green shed and bought one with the triton rip saw
    I’ve constructed all sorts of stuff with the help of the “tryiton”
    Only problem is storage, mine it out in the weather at the moment as I’ve run out of room it the workshop
    Time for that extension I thinksTriton WorkcentreTriton Workcentre
    1985 110 Dual Cab 4.6 R380 ARB Lockers (currently NIS due to roof kissing road)
    1985 110 Station Wagon 3.5 LT85 (unmolested blank canvas)
    Bunbury, WA
    Quote Originally Posted by Gav 110 View Post
    I've built timber furniture and all sorts with mine, a few years ago now.
    Its most handy (with the saw removed) as a relatively mobile table/workbench in the shed.
    Jan 2011
    Spare parts an issue, but a good tool tool.
    Triton was an Aussie invention (Portable saw using 9" rotary saw, worked as either blade-up or blade-down) 1980s or so. I've had two. The company was sold to GMC (cheap Chinese manufacture with a German engineer owner) just before the 2008 GFC (global financial crisis) and went bust at that point. Their last goods (2007-08) were of notably poorer quality than earlier.
    And while it's possible to use the luggs to 'universally fit' a different brand saw or a router, the 'made for Triton' saws and routers fit far more easily. Spare parts are a bit of a diminishing thing; getting harder to get but unless you've a huge shed and plenty of space, the multiple-use nature/small-footprint/portability of the base Triton saw is hard to beat. Worthwhile getting old Triton saws repaired.
    The tool is good enough for a ham-hands like myself to be mistaken for a carpenter (which I'm not!), if I use it carefully. One can make nice tight joins.
    And if anyone has a genuine Triton router, which is languishing unused, I'd love it. The GMC one (also no longer made) I've got just doesn't fit well enough in the cradle. I got the GMC because it was 30% of the cost of a genuine Triton - false economy.
    Narre Warren South
    Quote Originally Posted by Lionelgee View Post
    Lionel,
    Back to your first post.
    You'd struggle to make something as simple, easy to adjust & use as the Triton extension table.
    Yes you could make something, it would take a lot of time, it would never be quite as simple to use. If you're anything like me it would probably never happen.
    I forget what I paid for mine, because it was many years back, but the ability to cut down full sheets has been very useful.
    Maxi Sliding Extension Table | TritonTools.com
    The extension table parts hang on the wall of my shed when not in use.
    Rather than waiting for Triton gear to be advertised put a 'wanted' advert in a local shop/newspaper. Someone, somewhere will have one, could be a deceased estate, could be unused and in the way and they want it gone. The only concern when buying secondhand is.....is it all there ?
    Here's most of what you want and 'negotiable' Triton 2000 Workcentre and Triton 2000 Router Stand | Power Tools | Gumtree Australia Brisbane South West - Robertson | 1255012417
    You might want to get the seller to fit & demonstrate the saw & router as they are not Triton.
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
