Hi chillilife,
The first thing you must acknowledge is that you're not buying a $30k or $40k (or whatever the price is) car. You are buying a (ten years old) $100k car that was once a state of the art, leading edge 4WD. It was a complex machine with complex software and expensive servicing requirements. It still is, no matter how cheaply you can buy it today.
That said, there's no reason why a well maintained D3 won't suit you. But expect to pay for servicing and parts as though it was a new car.
At that mileage you will be ready for:
Timing belt replacement, possibly low pressure fuel pump and perhaps high pressure pump replacement. If doing a body off service it would be worth checking the lubrication between the transfer case and gearbox shaft. Allow a few thousand if all OK. Double that if other issues found.
Gearbox needs a service. If not used for towing or heavy 4WD it should be fine. Must be done by authorised ZF shop (in my opinion). Allow $774.
Front control arms are virtually sacrificial items, so no problems there. Allow $900 for parts plus labour plus wheel alignment.
It also pays to be on top of the air suspension maintenance and you should consider buying a diagnostic tool.
It also pays to be able to do your own servicing and maintenance. In any event, find a good indie. There's a few in Perth according to posts from locals and Dazza TD5 comes highly recommended and regularly contributes to this forum.
He'll probably come along shortly and correct me on this post!
				2013 D4 expedition equipped
1966 Army workshop trailer
