Results 1 to 2 of 2
Thread: Loose connection ?
    Andyr2577 Guest
    Wink Loose connection ?
    Morning guys and gals
    have an intermittent issue . It is related it seems to my BCM from the druse box under the passenger glove box .
    i did read on a service bulletin a while ago that there was a pin in the back of that fuse box that likes to work it’s way loose but I can’t seem to find that information anywhere ?
    just wondered if this rings any bells with someone on here or if they can point me in the right direction ?
    Thanks in advance 👍🏻
    NSW SW Slopes
    Have you tried searching fullfatrr.com or rrsport.co.uk for a specific fault or fault code that occurs on the L405 or L494? However I don't recall seeing any posts on fullfatrr.com in the last several years for similar-sounding faults.
