Results 1 to 8 of 8
Thread: BEWARE OF APPS FROM THE GOOGLE APP STORE
    Sussex Inlet. N.S.W.
    i was searching for an app to meet a need that i had. Having found it I installed it on my mobile, and that is where my trouble started. The app hijacked my mobile with the existing apps spread everywhere. Lots of stuff appeared on my phone that was not asked for. To top it all off the app delete function was blocked. I went into settings/apps and force stopped it, but after a time it would reactivate. I was stuffed. I downloaded Ccleaner and ran the program which deleted heaps of rubbish and I got my home screen back. Everything else was still totally messed up. I then thought about the program I run on my pc..trend micro. After spending hours attempting to install it on my mobile I finally succeeded. I hit the clean button and prayed. It showed one suspicious program and suggested I delete it. The one that showed was the app I had been trying to remove. One more click and the problem totally disappeared and all was back to normal. The app I had downloaded was WEATHER HOME. I have since found that this app is a well known TROJAN. I WAS LUCKY
    Jim VK2MAD
    '17 Isuzu D-Max
    Avoca Beach
    And the Android Users criticise Iphones.
    I have used Iphones for 10years and NEVER had a problem with rogue apps. Neither has my wife.
    Such is the beauty of the App Store.
    And I think Fortnite have a gall to criticise Apple for taking a 30% commission. I bet they make millions from the app anyway but they want MORE. It is only downloaded to the extent it is because it is verified Trojan free by Apple.
    Regards PhilipA
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    both stores have issues, apple is marginally better than android it has to be said but neither is definitely 100% safe
    android does some thing better than ios and ios does some thing better than android
    horses for courses...
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    St Helena,Melbourne
    4.28 MB
    always read the comments before installing any app.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    And also view the permissions you will be granting the app before you install it. Some permissions are needed for functionality, for instance a weather app can justifiably need access to your gps location etc. but does it really need access to all the permissions Weather Home wants to take.
    You gave it permission to do just about anything it likes. Does a weather app really need permission to modify your phone's system settings. Always be suspicious of any app that wants to take device permissions for reasons which seem unrelated to it's purpose.
    Weather Home:- This app has access to:
    Device & app history
    read sensitive log data
    approximate location (network-based)
    precise location (GPS and network-based)
    Phone
    directly call phone numbers
    modify phone state
    read phone status and identity
    Photos/Media/Files
    read the contents of your USB storage
    modify or delete the contents of your USB storage
    Storage
    Wi-Fi connection information
    view Wi-Fi connections
    Device ID & call information
    Other
    choose widgets
    adjust your wallpaper size
    read Home settings and shortcuts
    receive data from Internet
    view network connections
    pair with Bluetooth devices
    access Bluetooth settings
    change network connectivity
    connect and disconnect from Wi-Fi
    expand/collapse status bar
    full network access
    run at startup
    set wallpaper
    draw over other apps
    control vibration
    prevent device from sleeping
    modify system settings
    2024 RRS on the road
    2011 D4 3.0 in the drive way
    1999 D2 V8, in heaven
    1984 RRC, in hell
    Nov 2018
    Once I had to see a Sydney woman's iphone 8 with her scared eyes showing me the phone was hijacked by a person somewhere on the Earth. The phone was holding in her hands just trying to work as a ghost phone, all just like you are using iPhone but you can not touch control it, and you are not the person who is controlling it. None of the buttons on that iPhone could work as normal even if I and her trying to use any buttons to turn it off. It was playing like that until battery was out. And when you charge battery it plays again. Scary thing was that the person who hijacked it actually could hear what we were talking, so they tried to show off how they could control the phone from distance. I was speechless then.
    Avoca Beach
    So they had her password then?
    Or maybe her fingerprint or eyeball.
    Or was it "jailbroken" so she could buy apps from other than the app store.
    Regards PhilipA
    Mar 2018
    Hi
    Apps are very problematic.
    "And also view the permissions you will be granting the app before you install it. "
    Can't reply on that. My malicious app would not say what it really was going to use :-) You can't trust what they say will what it really does use. Apple apparently checks apps more than Google does so ensure they only use access that the ask for but its not perfect checking.
    The issue with Apple and Epic Games isn't just about the 30% its the fact that Epic Games enabled in-app purchases which Apple does not allow. Only the Android App store allow that. There are arguments on both sides and for Apple it's sailing close to US anti competition behaviour.
    Mike
