Yep. I have the same. Haven’t bothered to try and do anything about it
 YarnMaster
						Supporter
						YarnMaster
						Supporter TopicToaster
						Subscriber
						TopicToaster
						SubscriberYep. I have the same. Haven’t bothered to try and do anything about it
2007 Audi RS4 (B7)
 YarnMaster
						Supporter
						YarnMaster
						Supportertry some "De Solv it" on the rubbed area to remove the rubber (not too much as this stuff can remove paint as well) same on the rubber seal and then coat with Mr sheen furniture polish.
You may need to adjust the tailgate hinge a bit as its squishing the seal too hard against the body. There are adjuster screws at the top of the hinge to change offset. The door should lie flush or just proud of the rear quarter panel, and check if is square to the opening, the gap on both sides should be equal.
Dealer fitted some 3M film on the contact points on mine to prevent this.
