Thread: Charger for MY10 TDV8
    Jun 2008
    Hi, with the lack of driving and cold here in VIC I'm starting to get a low battery.
    I still have a JLR labelled Battery, not sure if its the original, but I haven't replaced it in 4 years. I am looking to get a charger to compensate for the lack of driving and would like to check if this is the right type if anyone knows:
    MXS 10 AUS CTEK Consumer
    Thanks in advance
    DiscoMick Guest
    Should be fine. Just set it to the type of battery (AGM, starting wet cell etc).
    Redarc and Projecta have similar chargers, as do a range of other brands.
    I have 3 Projectas and all are good.
    Basically, just want a charger which tests the battery, charges to about 80%, then slows down for the final 20%, goes to sleep and periodically wakes up, tests the battery, charges if required and then goes back to sleep.
    A solar charger is another option. It charges during the day and rests the battery at night.
    Check your manual to see if the negative should be attached to the battery or to a specified negative terminal in the engine bay.
    Kingston, Tassie, OZ.
    Oh. I thought this was a thread about trading the tdv8 for a dodge charger...
    Never mind me...😫
    Brisbane, Queensland
    For a couple of years I’ve used the MXS 5.0 for my 2008 L322, and all other vehicles.
    MXS 5.0 AUS CTEK Consumer
    I also have one of these attached to every vehicle battery. The indicator is in plain view when I walk past the vehicle so I can keep an eye on it. For example on the L322 it sits at the bottom of the windscreen.
    CTEK Indicator Eyelet M8 (0.5M) 56-382 7350009563826 | eBay
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    Mar 2013
    Gymea
    Repco have the Ctek MXS 5.0 on sale for $99 at the moment.
    Apr 2019
    Koojan WA (part time Perth)
    Quote Originally Posted by Blade74 View Post
    CTEK Battery Charger 5A with Bonus Power Bank and Accessories - 40-358 - CTEK | Repco Australia
    Comes with $95 of extras
    Good buyCharger for MY10 TDV8Charger for MY10 TDV8
    1985 110 Dual Cab 4.6 R380 ARB Lockers (currently NIS due to roof kissing road)
    1985 110 Station Wagon 3.5 LT85 (unmolested blank canvas)
    Quote Originally Posted by Gav 110 View Post
    That’s excellent value as includes the charge indicator connector. I paid around $150 for charger and indicator.
    REMLR # 137
    Jun 2008
    I missed the repco special as already ordered.
    but ordered 2 of these to try out, one for main battery and one for battery in the rear :
    CTEK Battery Sense Bluetooth Battery Monitor - 40-149 - CTEK | Repco Australia
    Jun 2008
    Charger has arrived - can I check is it the AGM battery that a 2010 L322 would have? (I have to set the charger)
    Brisbane,Qld.
    Quote Originally Posted by 2nd Rower View Post
    The 2010 4.4l diesel is supposed to have an AGM. Unfortunately if the previous owner didn't want to spend the money it may not have an AGM (yes I have experience with this ). You should be able to see enough of the top of the battery to tell what it is.
    TimJ.
    Gumnut - 1953 Series I 80"
    Poverty - 1958 Series I 88"
    Arnie - 1975 710M Pinzgauer
