So what are the issues with using modern high speed diesels for short trips? My older diesel freelander and my now 13 yo RRS is used mainly for short commutes and I have had no issues other than charging the battery from time to time but that applies equally to a petrol. Likewise wear because of use on cold engines etc are likely equally on both type of engines.
Now my vehicle does not have a DPF but from what little I know of them, the LR versions are pretty trouble free IF IF IF you read the instructions on their maintenance (like other aspects of servicing) and abide by them - doesn't the car tell you it needs a burn off if it has not been able to be done in normal driving conditions?
With over 400,000km in my two diesels I have not had any "commute" specific issues - but then my cars are maintained on time in accordance with the book (modified by common sense)
