Results 1 to 4 of 4
Thread: Interlocking retaining wall blocks
    Jan 2011
    Gippsland
    For a while now I’ve trying source these old style of interlocking retaining wall blocks and it seems that they’re not manufactured anymore. Does anyone know if they are still available somewhere ??
    LROCV member #131
    1999 build D2 TD5 Auto, Mantec snorkel, 2" LRA spring lift, ARB on board air, Ashcroft ATB, CMM air ram CDL shifter, swag & gold pans ....
    Feb 2010
    Bugger. I just gave and sold/gave away a heap of them last year. Mine where brought new over ten years ago and with a high pressure clean looked as good as new. If you use them try to put two rows of solids on top as that holds them down very well. I think bunnings had them at one point. You may like to check. I found the concrete sleepers very very good to use and a lot less work than I laid three one metre terraces using those bricks.
    Check gumtree and similar for them perhaps..
    Normanhurst, NSW
    They look similar to the Linearwall blocks - see following.
    Try National Masonry at National Masonry Concrete Blocks, Bricks, Concrete Pavers & Retaining Walls - National Masonry - see pics for their range of interlocking blocks.
    Roger
    Jan 2011
    Gippsland
    Quote Originally Posted by NavyDiver View Post
    Damn - and I’m in Melbourne area too! Interlocking retaining wall blocks
    LROCV member #131
