Results 1 to 10 of 11
Thread: Oil top up
    Dec 2014
    Townsville
    Oil top up
    My 2015 D4 td6 needs an oil top up.
    What oil should I use.
    Brisbane,some of the time.
    Try to use the same oil that is in the engine,that is if you know what it is.
    If not use any oil as per specs in vehicle service book.
    Sep 2014
    Baldivis WA
    Definitely not vegetable or olive oil.....
    Jun 2013
    Augusta WA
    Quote Originally Posted by Barraman View Post
    I wonder why you should be needing to top up the oil. What oil change interval are you doing?
    MY09 D3 TDV6 Zermatt Silver
    MY02 TD5 Bonatti Grey (Sold)
    MY00 TD5 520K (Sold)
    Kallangur, Brisbane
    Castrol EDGE Professional C1 5w-30
    + 2016 D4 TDV6
    Sep 2014
    Baldivis WA
    Penrite Enviro C4 5w30, C1 in the same grade is also OK.
    Dec 2009
    Baldivis WA
    Quote Originally Posted by Milton477 View Post
    Only if it has a DPF, which I doubt it does.
    The oil needs to meet or exceed Ford spec WSS—M2C913-B Or C for a non-DPF vehicle, or Ford spec WSS-M2C934-B if it has a DPF.
    How do you know if you have a DPF?
    Check the eighth digit of the VIN, F & N is without DPF, G & M is with a DPF.
    Or have a look at the exhaust as it passes under the passenger footwell.
    2014, MY14 Discovery TDV6, Fuji White (2018-Now)
    2003, Discovery 2a, Td5 Manual, Zambezi Silver (2012-2018)
    2007, Adventure Offroad Campers, Grand Tourer (2015-Now)
    DiscoMick Guest
    Is it correct if in doubt choose the DPF oil and it will work fine in a non-DPF vehicle?
    Mar 2018
    Perth (near Malaga)
    Quote Originally Posted by DiscoMick View Post
    Yep.
    Jul 2012
    Perth- South of the River
    I'm using Penrite Full Synthetic 5-30 in mine.
    Gone 05 D3 ARB Front Kaymar Rear Winch E-Diff LRA Tank Dual Battery
    Current 2015 SDV6 SE. Tow Pro Mitch Hitch Llams C/motives 70ltr w/tank 2 x comp Traxide BMS-2 x Aux 150w Solar Uniden Engel ARB drawer F/Runner rack Light bar
