Results 1 to 4 of 4
Thread: D4 wifi antenna
    aardvark Guest
    Question D4 wifi antenna
    Hi All,
    On my D4 I have no sat-nav so there is a plastic cover in the roof where the shark's fin should go. Does anyone what I would find if I took the cover off, eg bare hole with no wires, hole with antenna connectors etc, and if there are wires, where do they go? I am considering fitting a Telstra 4GX internet to wifi dongle somewhere.
    Thanks in advance
    Stuart
    Apr 2012
    Whyalla, SA
    Put Dongle under console.
    Oct 2020
    Australia
    Question 4G antenna fitting
    Quote Originally Posted by aardvark View Post
    Hi All,
    Thanks in advance
    Stuart
    Hi Stuart,
    Did you get an answer to your question?
    I also want to put at least a 4G antenna on the roof feeding my 4GX or something more sophisticated if necessary (celfi maybe). I can't find anything about the plastic cover/what's underneath it and so need someone topping me in the right direction.
    Barry
    Nov 2015
    Black Rock
    The blanking plate comprises two parts, with the top (outside) plate having two studs which the lower (inside) plate fastens up to. To access it you need to lower the rear section of the roof lining, which means moving aside both rear lower side panels, both rear end panels and both c panels. And the third row grab handles in the roof.
    2013 D4 expedition equipped
    1966 Army workshop trailer
