Results 1 to 3 of 3
Thread: 2010 L322 Tow Plug Electrics Bracket
    wamalwap Guest
    I would like to fit a tow electric plug on my 2010 L322.
    I have received the electrics but the kit I bought part number VLMT0007, does no come with the bracket which fits on the clamp that's part of the tow bar where the electric connection is secured.
    Can I buy the bracket separately as an independent part, or will I have to buy part VLMT0006 which has the bracket, even though the plug I would like to use is the 13 Pin one?
    Or is it a better option is to simply fabricate a bracket myself since it's difficult to justify buying the whole second kit when I will not use the electrics at all?
    Thanks.
    Mar 2007
    Hi
    SuperCheap Autobahn and Repco all have brackets you could adapt for between $7-$15, failing that any local caravan or trailer retailer will have them also.
    Laurie
    wamalwap Guest
    Thanks Laurie,
    Got one from Autobarn, took about an hour to modify and it did the job perfectly.
    Cheers!
