I think you need the Meridian upgrade for DAB.
 Fossicker
						Fossicker
						I've got a, you guessed it, TD6 SE but it has a couple of features missing that I expected to see ..
1. Sat Nav has no voice control
2. No DAB radio.
It has no badges at all but I'm 99.99% sure it's an SE. It has Electric seats and mirrors, DRL lights, Rain sense wipers, auto headlamps, twin glovebox etc etc, which when looking at the sales glossy are all SE features.
Is it possible that these two Incontrol Touch features are turned off somehow or there is an update I'm missing?
Or is this not an SE after all?
Any clues/advice appreciated.
 TopicToaster
						TopicToaster
In the specifications, DAB was a $920 (2017 prices) option but does not appear to be tied to any particular sound system. I have a Meridian upgrade on my SE but no DAB. As for the SatNav voice control, it's not that good anyway so you won't miss much.
2016 D4 TDV6 Corris Grey
2018 D5 TD6 SE Silicon Silver - gone
2011 D4 TDV6 2.7 Indus Silver - gone
IIDTool BT
Found the 2018 specs as well, DAB was standard on HSE and HSE lux, an option on S and SE.
IIDTool BT
 Wizard
						Supporter
						Wizard
						SupporterNot standard on my 2019 SE.
Bob
Indeed, it is standard from MY 2018 on a HSE or HSE Lux onwards. WhiteD3 has a MY18 HSE so his will have DAB, together with the Meridian sound system.
Ron
IIDTool BT
If you have InControl Touch (not the Touch Pro) then the head unit has been built without the DAB receiver in it. A factory DAB retrofit is possible but involves swapping the whole head unit over, as well as programming & adding the antenna.
The dealers won't be able to help you with that.
2009 Range Rover Sport 3.6L TDV8
2017 Jaguar XE R-Sport
Supercharged Jags XKR & XJR 4.2L S/C
Old Jaguar Australia - www.facebook.com/oldjaguarau
Upgrades and retrofits for late model Land Rover and Jaguar vehicles. www.oldjaguar.com
 Fossicker
						Fossicker
						Thanks all .. I guess I put it down to the myriad of options/if's/but's and maybe's that is Land Rover.
I found this:
In a MY17 brochure .. hence my questions. Seems a lot of things are variable depending on the model you have.
Cheers.
