The most i have ever got in mine has been 76L,which at times is a PITA.
As for range,don't really know,generally gets 9 to 11L/100 on a run,and 12 to 13l/100 around town.
 Member
						Member
						Hi all,
I've recently purchased a 2015 discovery and im curious to see what people have to say about the numbers im getting for fuel.
As quoted by Red book the fuel tank size is 82L with an average fuel range of around 932km. I understand you have to take that figure with a grain of salt but the two times I have now gone to fill the tank, I have not been able to put more than 70 litres ( thats with a range of less than 10km both times). On checking the range when filled up it has said with a full tank the range is around 660kms. The best fuel range I've gotten has been 640kms of standard driving with no load at all, mostly freeway and a bit of city driving. Now this seem quite irregular to me for figures to be this far out. Does anyone know if there is an issue here?
Thanks in advance guys and girls.
 Fossicker
						Supporter
						Fossicker
						SupporterThe unfortunate news is that sounds about right to me.
I usually cover between 500-600km per tank (indicator down to zero km or beyond), and it usually takes around 70 Lt. to fill. The most I've ever managed to fit was around 77lt, but that was after covering around 50km beyond the 0km warning...
Note - most of my driving during the week is in stop/start city traffic, rear of the vehicle always heavily loaded up with shelves, fridge and work tools, I have a full length roof platform & awning, and running LT A/T tyres, so I don't expect great economy.
Here’s a screen shot of my fuel record. The high figures were towing the 1.5-1.8 ton camper. Most of the time I’m driving around town, and I have Maxxis 980 AT tyres which east the fuel by an extra 1-1.5lt/100km.
"Land Rover - making mechanics out of everyday motorists for nearly 70 years"
 TopicToaster
						Subscriber
						TopicToaster
						SubscriberThe tank still has around 100km of travel (10L) in it when the range indicator hits 0Km. As for the range on a tank itself - overly optimistic they were for sure
2007 Audi RS4 (B7)
 YarnMaster
						YarnMaster
						I get much the same figures for driving when not towing, about 9 -11 per 100. Up to 18 when towing our small van and more with a headwind..... try Port Hedland to Broome when the easterly is howling along in the early morning.Why they can't put a bigger tank in these things I don't know.
But I never allow the level to drop below a quarter as I don't want muck from the bottom of the tank being sucked up, so don't know how much a fill from empty is anyway.
AlanH.
Gone 05 D3 ARB Front Kaymar Rear Winch E-Diff LRA Tank Dual Battery
Current 2015 SDV6 SE. Tow Pro Mitch Hitch Llams C/motives 70ltr w/tank 2 x comp Traxide BMS-2 x Aux 150w Solar Uniden Engel ARB drawer F/Runner rack Light bar
So what is the difference in the tank arrangement between the D4 and D3/RRS. Many people have complained about the D4 issue but I have no issue with my RRS as regularly put over 80 litres in its tank which is the same as a D3.
As there does not seem to be an issue with the tank system in the D3/RRS it would seem unlikely that they would have needed to change for the D4 - but clearly something is different.
Like some others here I have never been able to get much more than ~70 litres into the tank when supposedly empty.
Supposedly the diesel fuel tank has a capacity of ~82 litres. I suppose it retains ~10 litres for 3 reasons
1 To maintain some additional range when indicated empty. I'm guessing but maybe you get 5 - 6 litres for this.
2 After that ~5 litres is used the engine begins to simulate running empty. I guess you get to use a litre or so of fuel during this carry on.
3 After simulating an empty tank for a bit but before actually running empty the engine will shut itself down. The manual says it needs ~4l of fuel in the tank to restart. So I guess it retains that 4 litres of fuel.
~70 + ~5 + ~4 + ~ a bit adds up to near 82 litres.
2024 RRS on the road
2011 D4 3.0 in the drive way
1999 D2 V8, in heaven
1984 RRC, in hell
 Wizard
						Wizard
						With fantastic fuel figures like that when towing a brick you'd save enuf to put in a long range tank or rear bar or roof rack...and no more complaints. Or buy a cruiser fill up the massive tanks and see 22 plus l/100ks☺..oh and modify the suspension b 4 hand...just saying🙄
