Originally Posted by Phillip
To start the AULRO ball rolling:
Inspect the engine mounts?
Hi All,
I have just joined this forum so I am hoping there are knowledgable people out there.
My 94 Disco has developed an engine vibration that can felt through most RPM range (it was progressive over the last 30K). It idles rough but a constant RPM. With the clutch in and in gear the vibration is still there so this may omitt the drive train. Has anyone else had this problem or know someone that has?
Phillip
Mahn England
Ex 300Tdi Disco:
did the Tdi have a balance shaft...?
Hi have a look at the crank pully when the engine is running to see if its wobbling about, if the bolt hasnt been done up tight enough and comes loose the pully wobbles and starts wearing into the crank. also the fan,make sure it turns smoothly and all the blades are there,
Just another couple of ideas for you
Richard
The other areas I'd be investigating are the head gasket and injector/fuel issues.
Mark
harmonic balancer slipping ?
check the integrity of the steel/rubber bond.
Zook, no balance shafts on a 300Tfi, they are pretty agricultural when running at the best of times.
understatement of the year :POriginally Posted by rick130
2007 Discovery 3 SE7 TDV6 2.7
2012 SZ Territory TX 2.7 TDCi
I try not to let hyperbole get the better of meOriginally Posted by incisor
