Results 1 to 10 of 16
Thread: Attaching awning to original LR roof bars
    Hunter Valley, NSW
    Hi there,
    Have just bought an ARB 2.5m aluminium encased awning and it seems quite (very?) heavy. Is this OK to attach to the LR bars or should I look at Rhino Rack heavy duty bars.
    ARB advises that the awning 'simply attaches using Rhino Rack brackets - is this the case?
    Many thanks
    Grahame
    2016 Firenze Red Disco 4 TDV6
    2018 Firenze Red Disco Sport
    ... plus many previous!
    Brisbane,some of the time.
    Do you have LR bars attached to the LR rails?
    They are heavy my Foxwing weighs close to 19KG from memory.
    St Helena,Melbourne
    1.13 MB
    You just need 4 T nuts that slide into the channel that the brackets with bolt 2, i had rhino bars but its the same process.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Hunter Valley, NSW
    Thanks scarry - OEM LR bars and LR rails
    ARB states that the weight is 16 kgs, so looking good.
    ARB advises to use the Rhino brackets, but thinking of cruising the bracket section of Bunnings for 150 x 150 brackets and bolting through the roof bars.
    We won't be doing any serious off roading, no Cape, no Kimberley - just a couple of old farts cruising the country - with occasional 'soft roading'
    Hunter Valley, NSW
    thanks for that - will drop in to local repco, supercheap etc etc and check them out (20mm x 20mm)
    cheers!
    Jun 2020
    the OEM LR bars are rebranded Rhino racks (edit: maybe it was Rola) AFAIK. to attach the awning you unlock and slide the ends out, pull a bit of the rubber insert out and slide the T bolt into the channel. I'll get you photos tomorrow if you need.
    Hunter Valley, NSW
    Quote Originally Posted by Macadamia View Post
    Thanks Macadamia - my roof bars are LR Part VPLAR0001
    I can't see a bracket system extending from the bar channel out to the car body - seems to need about 200mm - from the aluminium channel, where it joins the black end piece.
    Hunter Valley, NSW
    Rhino rack RLT600 Quick Mount Leg
    The R-Rack dealer wants me to buy these - assuring me that they will fit and slide along the LR factory rails.
    Has anybody fitted these and had success (or story!)
    Jun 2020
    sorry my description wasn't great. I'll get you photos tomorrow of what I mean if they're the same OEM roof rack bars that I have
    Jun 2020
    my roof racks are currently off the car because I'm replacing the rubber insert and haven't gotten around to measuring and cutting it to fit my snowboard carrier. Anyway... here ya go. It's not an ideal way to fit the awning but it works...
    This is the OEM roof rack bars I have.
    unlock the end and open it up
    take the plastic cover out to expose the channel
    take the T bolt from the awning
    and position it in the channel where you need it. it may take some trial and error and adjusting the height and orientation of the awning to get it to work with these type of bars.
    You may also need to cut the rubber insert and keep a small piece removed.
    The roof rack bars I had on my old car had a better system where the rubber insert pushes down into the channel. No cutting and removing necessary. Lately I've been debating getting a platform instead.
