I did find the seal tight but somehow managed to get it done up and squished up
Last weekend's COVID project... installing the Front Runner Ladder to the D4.
The ladder is well made and comes with good instructions, but I did make some slight modification to the rubber seal that FR supply as it made it virtually impossible to bolt home the bottom mounting plate of the ladder. Happy with the result, a sturdy solid fit and a ladder that is pretty easy to climb. Some pics to show you what I ended up doing:
Removing the rear number plate light and camera housing is pretty easy ready for the fitting of the rubber seal that FR provide to seal and buffer the bottom metal base of the ladder that goes behind the light/camera housing. No hole drilling required, the FR ladder uses the existing mounting bolts to hold the base of the ladder firmly in place.
The rubber seal was about 4mm thick and really caused some grief in reattaching the rear housing with the ladder plate... as the extra thickness of the rubber seal strip made it crazy difficult to relocate the bolt threads through the holes in order to get the nut threads to align. Despite lots of clamps, pushing and attempts to reattach the nuts... the answer was to shave down a couple of mill with the Dremel. Otherwise it would have been a trip to Clark Rubber for a thinner strip.
With the thinned down rubber seal and padded out clamps it is then possible to get a socket onto the mounting nuts and screw them home.
The top bracket attached with the tailgate door hinge bolt hods firm the top mount of the ladder.
All up, happy with the result and a neat sealed finish.
The ProSpeed ladder from the UK was my first choice as I liked the lower step that they provide, but the crazy high cost to import from the UK, and some feedback from others on the forum made Front Runner, the Front Runner for install
Naps
MY16 D4 SDV6 HSE 3.0L MOAB 265/60R18 KO2 - Carbon 12K Winch - DO 35 Hitch - RedARC TowPro - Rhino Rack Backbone & Pioneer Platform - Front Runner Ladder - 100Ah 'The Lithium Box' - Full Boar Fourbie Drawers & Travall - APT Front/Sump/AC/Sliders - Safari snorkel - Oricom DTX4200 - Cel-Fi - GAP IID - TyreDogs
 TopicToaster
						Subscriber
						TopicToaster
						SubscriberI did find the seal tight but somehow managed to get it done up and squished up
2007 Audi RS4 (B7)
That looks great, and no interference with the rhino rack? I've been meaning to get the FR ladder for mine, but I thought it would hit the rack as the tailgate door swings up.
 TopicToaster
						Subscriber
						TopicToaster
						SubscriberI recently bought the Front Runner LR3/LR4 ladder (LALD004). I tried to install it today but I can see no way that the holes on the bottom plate will line up with the light cluster holes. I have sent an enquiry to Front Runner. I will post the reply in case someone else in the future has a similar issue. My bet is the top plate, and possibly base plate, has been welded at the wrong angle.
Standing on the rear step or even wheel works for me, don't see the need for a rear mounted rust magnet.
2004 Jayco Freedom tin tent
1998 Triumph Daytona T595
1974 VW Kombi bus
1958 Holden FC special sedan
