Results 1 to 10 of 12
Thread: Defender Drive-by-Wire Accelerator
    Gascoigne Guest
    Does anyone know if the drive-by-wire accelerator in Defenders (mine is '99 Xtreme) can be reconfigured?
    I find that, in high range, there is no response at all for the first few centimetres of pedal travel, then I get what seems like all of the acceleration over a very short distance of subsequent pedal travel.
    Has anyone else found this a problem? Tend to find myself stalling a bit or revving it a bit more than is necessary.
    Is it just a matter of getting used to it?
    Eidsvold QLD
    I think its supposed to be like that.
    It's a PITA & it was changed in later years. If it's the scenario I remember, you can't even blip the throttle when double de-clutching, it just won't respond.
    Solutions? Search for the threads on the clutch mod, pulling that connection might help. Other than that, it's an update to a later ECU I guess.
    Max P
    Kurrajong Heights NSW
    Gas - I have a Bruce Davis chipped vehicle and know that there is a "throttle Track" setting that can be modified when setting up the computer (there are basically 2 sensitivity settings). Dont know if a standard computer has this facility. Have played with this at Bruces workshop and the settings make a massive difference to throttle response at the pedal.
    Daz
    Gascoigne Guest
    Thanks. Mine's Bruce Davis chipped so will look into it.
    Yass NSW
    Mine is chiped and I find the same thing. But get the right point early on and wow its like someone lit a fire under its ****.
    As far as I was aware that was designed like that so there was more control in low range
    Series 11A ex Air Force
    1995 ES Discovery TDI
    RIP 2006 Discovery 3
    RIP 2004 V8 Discovery
    RIP 95 Discovery TDI
    RIP 1999 Freelander
    RIP 1978 EX Army FFR
    Toowoomba QLD.
    Quote Originally Posted by DiscoTDI
    Yes but only in low range. The ECU alters the throttle input for highway (high range use).
    Trev.
    Quote Originally Posted by disconut
    Trev.
    Im thinking BC (Before Computers)
    RIP 1999 Freelander
    Williams West Aust
    Im sure this has come up before,the cure was to select lowrange and re select hi range to reset the computer.
    perhaps being chipped confuses the computer somewhat????
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
