Do you have DSC turned off?
Just wondering why whenever I tackle a very steep Hill, in rock mode, I experience a huge loss of power. Sometimes to the point where I could put the pedal to the ground, and it won’t move at all. Anyone else experienced such a thing? Can’t find any other threads here, with the same issue. Cheers.
 Swaggie
						Swaggie
						How's the gearbox oil level?
You realise that the throttle response is reduced in rock crawl mode ?
2004 Jayco Freedom tin tent
1998 Triumph Daytona T595
1974 VW Kombi bus
1958 Holden FC special sedan
I had the same thing when tackling a steep muddy hill. I put it in rock crawl as i thought the quicker it locked the centre diff and stopped wheels spinning the better. What i found was that the computer would cut throttle if it sensed spinning wheels and sudden changes in any direction, such as jostling from either from ruts or bumps.
I figured it was programmed to think, in that situation, that control had been lost and cutting power was the safest option. That or the higher speed was freaking it out (i wasnt exactly crawling).
I never got a chance to try the same hill in mud ruts or sand mode though i am assuming they would have performed better as they allow more wheel slip and jostling before stepping in.
And yes, even with the DSC off the DSC can still intervene.
If you get a chance try the same hill in mud ruts or normal. Sand mode will give you very sudden throttle response so i wouldnt recommend it first thing.
And let us know how it goes!
Dan
It is likely DSC kicking in, which does happen in various modes. Some more aggressive than others. From memory mud/ruts is the least aggressive as it expects a certain amount of wheel slip.
I think also it sometimes has a self preservation mode kick in. A few times i have been bound up on a rock ledge or in mud and no matter how much i want power, computer says no. I put this down to some smarts which is protecting components.
