Results 1 to 10 of 22
Thread: Bolt head in rear diff..
    Oct 2011
    Burra NSW
    Hi, found this in my rear diff today, 2012 130 ute.. carrier bolt head by the looks?
    Diff hasn’t been making any noise or any issues, what’s the best replacement option?
    JDNSW's Avatar
    I'm thinking it is the head off a bolt holding the crown wheel. If it has broken off, what are the others like? As a first step consider jacking up a rear wheel (chock front), handbrake off, remove the level plug and see what you can see as you rotate the diff. If it is a salisbury, remove the rear cover to have a look. If it is a Rover diff, you can fairly easily remove it by pulling both axles, disconnect prop shaft and drain it.
    With either diff type, you need to be certain where it came from. If you are lucky, it is a leftover from a previous repair and no further work will be needed. If it is one of the bolts holding the crown wheel on, replace all of them with new ones, correctly torqued (ff a head has broken off, were they overtightened? or faulty bolts?). I am not sure, but you may be able to do this (one at a time) without further disassembly. If it is quiet, and this is the only repair needed, then you should not need to make any adjustments.
    Jan 2014
    Perth Western Australia
    Yes as noted its a crown wheel retaining bolt (well the head anyway). The P38 diff if you work them, towing, offroad can break them. When you pull the diff out you will likely find bolts next to it broken and bolts on the opposite side of the crown wheel broken.
    Good time for a rebuild, while it may not be noisy yet I would say there will be plenty of backlash in it.
    Daz
    Oct 2011
    Burra NSW
    Thanks, Ill pull the diff out in the morning, definitely crown wheel bolts. its at 200,000k of hard off road and towing, so I think I will go an Ashcroft conversion, but will renew all CW bolts in the mean time.
    Are there any Ashcroft diffs available in the country or are they an order in from OS?
    Jan 2014
    Quote Originally Posted by Summiitt View Post
    *Direct from Ashcroft it wont take long to get here, the new ATB for the P38 doesnt need the spacer ring fitted.
    *Replace the bearings while you are there.
    *Also if as you say hard offroad and towing, its likely going to need a new crown wheel and pinion.
    *Once carrier is removed, check the bite pattern and amount of wear on the teeth.
    Daz
    Ipswich QLD.
    G'day Summitt,
    If your crown wheel bolts were like the ones on my front diff, (2002 Td5 130) they have serrations under the head face, the serrations dig into the cast iron carrier over time, and allow the bolts to loosen. I replaced mine with ARP bolts, with a smooth face, after needing to replace my crown wheel and pinion after it chewed though a few bolt heads. In my opinion using serrated head bolts against cast iron was a very poor design.
    arp-bolts.com
    Mick.
    1968 SIIa SWB
    1978 SIII Game SWB
    2002 130 Crew Cab HCPU
    Oct 2011
    Burra NSW
    Well, every bolt had sheared off, and amazingly none had gone through the CW/P. Given the vehicle is off road nearly everyday, everything is in perfect condition.
    Ive put it all back together with new HT bolts and will look into a new locker and fresh bearings etc.
    Its incredible that the vehicle showed no signs that anything was wrong with the diff, zero noise or backlash, probably got it just in time before it exploded all together!
    Feb 2014
    Wow!
    Buy a lotto ticket!!
    Phil B
    Custodian of:
    1974 S3 swb wagon (sold)
    1978 S3 swb canvas
    48 749 '88 4x4 Perentie
    1985 County with 4BD1T
    JDNSW's Avatar
    Were the bolts sheared (failed between C/W & carrier) or the heads detached? Which would most likely be due to overtensionedor faulty bolts.
    Jan 2019
    Belgium
    The bolts are often not loctited from factory, although the overhaul manuals mention that it should be done.
    My front diff ate a couple of bolts last year, I could remove most remaining crown wheel bolts by hand. It probably isn't a coincidence that this happened a couple of weeks after a trip with lots of corrugated roads.
    I used allen bolts with nordlock washers and loctite 270. I didn't reuse the diff housing (installed an ATB instead), but my indie told me to have the serrations milled flush in case I wanted to do so.
    Joris
