Well known problem...
Best options are Ashcroft or LOF
LOF EXTREMEspec MT82 Output shaft kit for Defender TDCI - Land Rover Clutches
 Member
						Member
						Hi All
New to the forum
I own a 2015/16 Defender 110
About 8months ago I had a clutch failure on the road
As I was out of warranty I had a mate replace the clutch assembly and all seemed well.
I was however unable to get any drive , just a metal on metal grinding sound when the gear was engaged
Due to a lack of time and other priorities I had to let the vehicle site for a while
ive since had my mechanic mate further investigate and he thinks it’s a shaft issue as seen in the pics
could someone help ID the part for me
and 2) if there is an after market product available or if it’s recommended to go genuine
And if so where I would go to source the part
Is this a common issue ? Or is there more underlying damage I need to be looking for
and lastly should the vehicle go to someone who is a LR specialist
(My mate is more of a new car mechanic )
Any assistance will be appreciate so I can get the beast back on the road again
I believe it is a common issue (I don't have a Puma, so I have not paid attention too much) and there should be no other damage than the two parts that mesh. Try a search (both this site and elsewhere) on Landrover Puma adapter shaft. I suspect the clutch replaced was perfectly OK!
Seeing a Landrover specialis (not a dealer) would probably be worthwhile.
 Master
						Master
						Ashcroft also do an upgraded slave cylinder.
If you kept the old clutch I cut the drive spline out of it and welded to a piece of flat bar and used this to mechanically lock the gearbox while fitting the adapter shaft.
Mark
As Tombie said, unfortunately its a common issue with the Pumas with the MT82 6 speed box....my output shaft was no where near as bad, but I replaced with the Ashcrofts kit...Ashcroft Transmissions
There's also an instructional video from LOF on how to fit their output shaft....LOF EXTREMEspec MT82 fitting video - YouTube
 Member
						Member
						I bought mine from Les Richmond here in Melbourne...Les Richmond Automotive
But British Off Road on the Sunshine Coast also sell Ashcroft gear
 Member
						Member
						I’ve found one Supplier in Aus
does this look like the correct thing to buy?
MT82 Output Coupling Shaft Kit
Yes that's it....
