Results 1 to 3 of 3
Thread: Defender 130 water leak into cab finaly fixed.
    Nov 2007
    Townsville Nth Qld
    Well after 3 months of intermittent rain and one wash first in three years ( dont want to spoil the old girl) I'm proud to announce i have solved my water leak. After searching you tube and jamming butal sealer every where. I thought i would run a bead of sica flex along the lower windscreen join over the seal as a last resort. Replaced roof liner last year and did not want to strip it down to replace seal. Bugger me last rain went out to go to work with much trepidation. Floor mat dry and remains so. Hope this quick fix helps someone. Looks ok and my beast is for off road use so im not overly worried about looks . saying that you would have to look close and be a rover guy to notice it
    May 2009
    West Gippsland - Victoria
    It's only stopped leaking water because the oil leaks have sealed up the water entry points
    Deano
    66 SIIA SWB .......73 SIII LWB diesel wgn
    86 RR 'classic'......99 Range Rover P38a
    94 Defender 110..95 Defender 130 Ute
    96 D1 300TDi.......99 D2 TD5 (current)
    04 D2a Td5..........02 Disco 2 V8
    I thought the solution to the roof water leaks was the lower doorseal leak....
