Thread: 16 gallon tank mount
    Cooroy, QLD
    Hey all,
    can anyone share a pic of how the 16 gallon tank mounts at the front? I know the outrigger gets cut off and moved to the bulkhead outrigger, which I'm in the process of doing, but the inner bolt hole is flush against the bottom of the outrigger. Do the military installs just leave this bolt out, or is there some other fancy solution?
    Adam
    australia
    hi i am breaking a militry s3 will check tomorrow for you jim
    Russell Rovers
    Series I Parts Specialists
    russellrovers AT gmail.com
    Phone 0428732001
    Jan 2017
    ACT
    I'm interested to know this too, I have 2 16 gal tanks but never knew how they mount at the front.
    Narre Warren South
    Quote Originally Posted by akelly View Post
    Hey all,
    Adam
    Pictures of the tank on my shorty, I can take a picture of the IIa GS if needed.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Cooroy, QLD
    oh wow that's a lot lower than I thought! Thanks
    Narre Warren South
    Seems to depend on the tank....
    Checked the FFR (the IIa is twin 10 gallon tanks) and tank is higher up with only two bolts in the front bracket.
    FFR tank is original, shorty tank is aftermarket but quite old. So were the aftermarket 16 gal tanks different ?? Were the military tanks different ??
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Cooroy, QLD
    ah yes that's exactly how mine looks with the tanks I have. I got mine made here in Melbourne. Could I trouble you to know if the tanks are level with the chassis at the top, in the section under the floor? Mine need to sit about 20mm proud and then the mounting rail is in that same position as your second lot of pics. It looks as though they just omit the inner bolt, which is what I was thinking of doing.
    Narre Warren South
    I'll have to take a look and get some more pictures.
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Narre Warren South
    Had a quick look, well feel really.
    The piece of the tank under your feet is level with the top of the outrigger on the shorty.
    I would think if you offered your tank up and attached the rear mount, when the tank sits level it will dictate the position of the front mount.
    Front is bolted direct and rear uses a rubber mount, easy to take a picture if needed.
    Fitting Kit for 552174 Fuel Tank - Paddock Spares
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Cooroy, QLD
    Quote Originally Posted by gromit View Post
    Colin
    No pics needed, that's all the info I require, thanks. I was thrown off because the 16 gallon tanks I had made sit much lower than the OEM 10 gallon ones and I had assumed that the extra volume was just the part under the floor. It was tricky working out what was 'level' because my driveway isn't level, but I've now taken a bunch of measurements so it should be close to right.
