Page 1 of 7 123 ... LastLast
Results 1 to 10 of 70
Thread: Now we wait as well!
    Jul 2019
    AU Brisbane
    2 weeks ago my 2014 Disco 4 SDV6 suddenly developed a clatter in the engine. Got my JLR dealer to check it out. Diagnosis is snapped crankshaft near #1 cylinder. Recommended remedy, new engine. I was a bit surprised as the car has done 59k and has had all its services.
    I've asked the dealer to approach JLR Australia for help as its obviously a design/manufacturing fault and same problem has occurred before to quite a few other Disco 3 and 4s. Just praying that they will come to the party like they did with M005!
    Cheers I will keep you posted!
    Jul 2019
    AU Brisbane
    I spoke to my indy. Seems he has 2 Disco 4s in line for a engine replacement already. Cost using 2nd hand engine 25k plus. New engine is twice that. There seems no logic as to which engines fail. But danger period seems to be 50k to 100k. Ones past that seem to be less likely to fail?
    May 2014
    Point Cook, VIC
    Not a good or fun position to be in.
    One thing to consider - if you can get a new engine then you should end up with the modified parts, like the improved crank design, which Ford put into the F-150. Plus a new engine should come with a warranty. In this regard M005 probably won the lottery.
    If you get a second hand engine, then you are back to the same level of risk as you originally had with no warranty.
    A rebuilt engine with a new modified crank and a warranty would be a good alternative but you have to make sure you know where the parts are sourced from. If the engine rebuilder won’t prove where the parts came from - don’t deal with them.
    Well worth pursuing your claim first before committing to any repair.
    Good luck.
    Jul 2019
    AU Brisbane
    Quote Originally Posted by DiscoDB View Post
    Good luck.
    Thanks DiscoDB
    Just had call from local dealer. JLR Australia has agreed to provide all parts free of charge and I pay for installation only. Circa $10 K assume. Still a big win outcome! I'm very grateful to JLR Australia as its all good will! Still if you buy 2nd hand D4, buy it from a dealer who has first sold it and make sure all services are by JLR!
    May 2014
    Point Cook, VIC
    Great outcome. Sounds like JLR are truly coming to the party at present.
    Fully agree with your comment if buying a D4 with the 3.0L - only buy from a JLR dealer, make sure it has been fully serviced by them, and I would add - discuss warranty up front (stated and implied).
    Jul 2019
    AU Brisbane
    Yes, discuss with JLR before deciding on repair of Disco 4 crank. They may be prepared to assist for good will.
    Feb 2019
    Does this issue seem to mostly happen in SDV6 as opposed to TDV6 in D4 or is it random?
    Aug 2018
    Sorry to hear this happened to you too, but glad you got a positive outcome too. I've been told the new LR Engine comes with a 12 month warranty, not sure why its not 3 years like they offered when the vehicle was new, but better than nothing and hopefully comes with modified parts.
    Which dealer is your at?
    @Birdboy - it seems that it is the 3.0 V6 that it happens too and doesn't matter whether it is in TDV6, SDV6 or RRS tune.
    I'm tempted to ask if they can put a SDV6 tune on mine, given it's exactly the same engine in the MY15 D4's.
    D4 TDV6 MY15, Llams, 18" Compos, BFG KO2's, REDARC DBS, Rhino Platform & Mitch Hitch
    Previously;
    Aus - '05 D3 TDV6, '08 D3 TDV6
    UK - '96 D1 300TDI, '95 Def 90 300TDI, '92 Def 110 200TDI, '95 D1 300TDI, '04 Freelander TD4, '
    88 90 2.5n/a, '95 D1 300TDI
    Apr 2007
    Newcastle NSW
    Glad to hear that they have come to the party for you Art. Ours is humming along very nicely since the replacement (almost 2000k's ago now). I imagine we may not have had as good an outcome if we'd held the line with JLR as ours was much older and more kms than yours and M005's. Good outcome none the less.
    As much as I shudder at the $16k we're out of pocket, the result is a much better vehicle than anything at twice the cost on the market. Happy Disco 4 owner.
    Just arrived: 2012 D4 3.0 HSE, the journey begins again ;-).
    Gone: 98 Disco 300tdi Auto, and some extras
    Aug 2018
    Quote Originally Posted by goldey View Post
    Have / do you have any issues with trusting the vehicle again?
    I'm hoping that I can fall in love with it again and have 100% confidence in it, as I can't think of anything else I would want to drive instead without it feeling like a step down.
    Previously;
