Results 1 to 9 of 9
Thread: New engine
    Nov 2020
    New engine
    Hello. I have a 2011 Defender which despite religious servicing has developed excessive blow by. After a recent diagnostic trip to local LR specialist they have recommended a new engine. It is a 2.4 litre Ford TDCI Duratorq. I have been recommended to do some homework on sourcing it myself to see what is available and I was wondering if anyone could recommend a good place to purchase a new long engine?
    Feb 2014
    Check eBay
    There are new engines advertised
    Phil B
    Custodian of:
    1974 S3 swb wagon (sold)
    1978 S3 swb canvas
    48 749 '88 4x4 Perentie
    1985 County with 4BD1T
    Back down the hill.
    Try this stuff, it's not snake oil, it really works.
    FTC Decarbonizer - Cost Effective Maintenance
    No connection etc..
    Sep 2010
    The Hills.
    152.79 MB
    No connection etc..
    Seafoam is pretty good as well, if you can find it.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Aug 2011
    Stanwell Park, NSW
    666.1 KB
    If you want a long motor, reach out to Transit Automotive in Clayton VIC. not sure of current pricing but they quoted me a few years back $7k for a roll in drive out new long motor. If you have 150k+ on the engine, do the injectors (about $400 each) and inspect the fuel pump ($2400). Bailey Diesel sell recon fuel pump and blueprinted recon injectors (and turbos).
    If you want a cheaper option pull the inlet manifold and intake and clean it. My intake was gummed up with carbon so bad it was like it a 3 pack a day smoker. Doubt it will solve the blow-by. that generally is worn rings.
    MLD
    Current: (Diggy) MY10 D130 ute, locked F&R, air suspension and rolling on 35's.
    Current: (but in need of TLC) 200tdi 110 ute & a 300tdi 110 ute.
    Current: (Steed) MY11 Audi RS5 phantom black (the daily driver)
    Gone: (Dorothy) MY99 TD5 D110
    Jul 2011
    Quote Originally Posted by MLD View Post
    They did mine a few years ago.
    Short engine around 5k,
    injector around 700 each,
    new intake manifold,
    rebuilt turbo around 1.2k.
    reused other accessories.
    Nov 2014
    wauchope
    Blow by
    If your engine is starting fine cold and doesn’t appear to have lost any power give me a call and I will tell how to fix.Many a workshop have replaced 2.4 engines for this reason and did not need it.
    Grinna 0400328407
    May 2015
    batemans bay NSW
    blow by
    Can you give us more information on the problem. What are the symptoms, how did you detect it, is the engine using oil, did it come on suddenly, what sort of oil are you using, are you servicing it, or is it a dealer or mechanic.
    Dec 2020
    Re seat the injectors? And new seals
