You don't need a Land Rover specific tool. I just had a generic cam locking kit and it had the 2 locking pins you need. You could even use a couple of drill bits.
Hello
Anybody have this? willing to sell/rent?
Part number DA1115.
It seems silly to spend 45 pounds plus postage for a one use item.
Julian
Build date 11th Oct 2003
LROCV #1410
04 L322 Vogue V8 - Work truck
07 Freelander 2 TD4 SE - The wifes
74 Leyland P76 Targa Florio - Aspen Green
91 Kawasaki GPZ900R
Previous LRs = 78IIa series - 81, 93, 95 RRC - D2V8
Yes, I was thinking, what is the diameter of the pins? But a drill kit would have a few variations in size. Why lock the flywheel as well as the crank shaft? The fly wheel is bolted to the crankshaft. T withstand the torque of undoing the crankshaft pulley bolt?
LROCV #1410
You don't lock the flywheel AND the crankshaft, you lock the crankshaft with a pin at the flywheel. And lock the camshaft on the drive pulley with a pin to the head.
The pins I used from my kit are both a tad over 6.5mm. They are nothing special, just mild steel pins.
Timing kit installation Land Rover Free Lander II 2.2 TD4 - Engine: 224DT - YouTube
91 Kawasaki GPZ900R
The Land Rover workshop manual specifies to lock the fly wheel with the pin and with the tool that engages on the flywheel teeth.
I am thinking that undoing the crankshaft pulley bolt could bend or break the fly wheel locking pin.
LROCV #1410
 Master
						Supporter
						Master
						SupporterIf you have any issues with doing the job, just do what the manual says.
91 Kawasaki GPZ900R
LROCV #1410
