7th December 2020, 08:16 PM
2004 central locking issues
Hi all
I have just replaced the 10AS and the ECU have talked to each other on a computer had everything set (key fobs) and I still have no central locking!!
I check fuses and have pulled the drivers door card of looking for shorts but no good.
anyone have any ideas or hints??
8th December 2020, 06:05 PM
It is possible to burn out the little motors in all of the door lock actuators at once if there is a fault that applies continuous power to the system. Might be worth pulling an actuator out and see if it can be operated on the bench.
