Results 1 to 8 of 8
Thread: Oil Gurus / Farmers :- advice needed.
    Apr 2018
    Blampied
    70.89 MB
    hi folks.
    i got conned into rebuilding my next door neighbours drum mower. its an old " Deutz Fahr KM 22 " he bounced it off a few rocks etc .
    parts ordered from uk. etc and rebuilt.
    searching web results in " EP 00 " as the grease / oil of choice ??? "EP " = extreme pressure. "00 " viscosity ( grease that flows like syrup ) ???
    not on shelf of your local auto store . any ideas. ?? given the fact that the machinery in question should be " garden art " i don't want to spend $$$$ .
    can i make my own brew ?? 80w90 plus ????
    thanks for any info.
    pete .
    Aug 2012
    Encounter Bay
    Mower
    G’day Pete,
    i presume it it is just a simple gearbox transferring power from P.T.O. to the belt drive,
    so any oil suitable for final drives on tractors would do,
    So yup,,make your own.
    Make sure the breather is open.
    Apr 2018
    Blampied
    70.89 MB
    thanks for the reply.
    if you google " Deutz KM22 " you'll get a pic of similiar machines. problem area is the section above the drum mowers. its a bath shaped area filled with " EP 00 " . its where belt drive input is transfered to horizontal shaft , and then through gears into vertical shaft etc.
    hope i explained that correctly ???
    the little oil that was in it was like treacle and water contaminated.
    info i found on U.S. farming forums suggests that any " thin " auto oil will just work its way down and drain away.
    pete :-)
    NSW far north coast
    NLGI 00 greases are available but often it's an order in item.
    And most all blenders make 00 greases, e.g. Penrite label theirs a 'Semi Fluid' grease.
    FWIW Land Rover 'One Shot' swivel grease is an NLGI 00 grease with 3% MOS2, satisfying an EP requirement, but it's only usually availabe in 400-500ml sachets
    Apr 2018
    Blampied
    70.89 MB
    thanks for the info " rick130 "
    looks like a trip to town is called for next week. i'll pop in to an agri dealer or two and see whats out there.
    from forums it seems approx 2 1/2 ltrs is required.
    expensive bit of garden art i think. :-))
    Aug 2012
    Encounter Bay
    Got that Pete, I had the wrong bull by the wrong horns.
    CV grease.
    roughly 50% grease and 50%80/90 mineral gear oil will yield about the right consistency
    Oct 2007
    Wantabadgery, N.S.W.
    Search;
    'https://www.google.com/search?client=safari&rls=en&ei=pVjUX-H2HIa-9QOlt7iIDg&q=self+levelling+grease.+Australia&oq=s elf+levelling+grease.+Australia&gs_lcp=CgZwc3ktYWI QAzIICCEQFhAdEB46BAgAEEc6CQgAEMkDEBYQHjoGCAAQFhAeO gQIIRAKUKD5AViPmAJgyJwCaABwAngAgAG2AogB1ROSAQcwLjM uNy4xmAEAoAEBqgEHZ3dzLXdpesgBCMABAQ&sclient=psy-ab&ved=0ahUKEwih3Yut3sftAhUGX30KHaUbDuEQ4dUDCAw&ua ct=5
    Take your pick
    Don.
