11 inch Brakes?
20201210_153722.jpg The cylinders don't even look like what in the manual.
Hi again..
I have inherited a 1962 Series 2a SWB from a hard line outbacker who had it since new, however he took all the information to the grave with him so unable to question about any changes made over the years. I only a Series 2 88 and 109 workshop manual and owners book to work on.
I had ordered brake parts prior to disassembly to find that this vehicle has LWB 11 inch brakes and a hub not mentioned in the manuals, can any shine so light on this?
I had never owned such a vehicle and i remember the old bastard never talked about his landrover or even driven it as long as knew him over thirty years.
20201217_065654.jpg 20201217_065643.jpg what are these?
11 inch Brakes?
They are freewheel hubs.
In 2WD they can be disengaged so you aren't turning the halfshafts as you drive. Supposedly they reduce fuel consumption but they also stop the Railco bush getting splash lubricated.
In 4WD they need to be manually locked otherwise there is no drive to the front wheels, the halfshafts just turn inside the freewheel hubs.
Colin
'65 Series IIa Dormobile
'70 SIIa GS
'76 SIII 88" (Isuzu C240)
'81 SIII FFR
'95 Defender Tanami
Motorcycles :-
You must have the wrong manual.... they look correct for LWB front brakes
Wheel cylinder LWB 4cyl front & SWB front LH fr 80/81 - TRW Lucas - Paddock Spares
Colin
'70 SIIa GS
'81 SIII FFR
'95 Defender Tanami
Motorcycles :-
My reply got lost when a storm came between here and the satellite, but I agree with Colin. And note that if you have lwb brakes on the front, check what you have on the back and what master cylinder. Also note that the lwb brakes are different width on the six, but these look like the four cylinder ones.
I have seen those free wheel hubs before, but not for many years, and I have never had anything to do with them, so cannot comment on them. They were rare.
11" brakes on a swb is something I did on mine, so perhaps was just a modification based on personal choice perhaps? Never seen those FWH before, the design isnt the best IMO as you got a flat slot to twist - i think this would be flogged out in no time if used regularly. I wonder if one can modify/swap out that fitting so that you have a hex head (like a nut/bolt) to get a ring spanner on it instead.
Carlos
1963 Land Rover Series 2a 88
Depends on the use of the vehicle, although I suspect that is partly why they were never very popular. My free wheel hubs stay engaged 99% of the time, and are disengaged for the annual pink slip trip to town, or to Cooma a couple of years ago. But my pick of freewheel hubs is the Warn ones I have. I got them at a clearing sale for $20 attached to a swb chassis less engine and gearbox but plus a tub and cab back and roof.
The freewheeling hubs also saves wear on the front driveshaft - supposedly the fastest wearing part on a SWB Series Landy. When disengaged ('out') the front drive is disconnected at the hub and at the transfer box.
However, I was never a fan of freewheeling hubs and found that they didn't reduce fuel consumption noticeably.
Roger
I am the same, I have them running pretty much engaged all the time as the donor S3 front end I pulled them off had the unis completely destroyed in the swivels... apparently a sign of not enough oil being splashed around inside by leaving them disengaged for too long. I have the M11 ones.
Tassie being so hilly, I found that when I am running them disengaged for a highway run up hills, in one particular hill I got a 10kph difference, 50kph engaged, 60kkph disengaged. So for me its more about that extra speed rather than fuel consumption, even tho my little 2.25 is super economical!
Carlos
