Results 1 to 4 of 4
Thread: Non Adaptive Struts on Adaptive Car
    Jun 2008
    Can you fit Non Adaptive Struts on a car with Adaptive Dynamics?
    If so what are the implications if any?
    NSW SW Slopes
    Yes standard shocks can be fitted. The CCF will need to be changed to indicate non-adaptive shocks are fitted to avoid the error messages. The power fuse for the adaptive ecu should be removed so that the ecu can't send messages on the canbus.
    Jun 2008
    Is there a way to tell visually the difference of what is cited to the car?
    Mar 2007
    The Adaptive shocks have a small wiring harness coming out of the top of the shock on the engine side !
