Results 1 to 2 of 2
Thread: EVC iDrive Throttle controller
    Apr 2015
    Hervey Bay
    So I've received and fitted the EVC iDrive Throttle Controller to my wife's 07 TD4.
    Does it make a difference? HELL YES! I would say it is the best bang for buck performance upgrade you can do to a TD4.
    Although the wife doesn't like it and had to turn it off for her. Too sensitive to what she was used to.
    I tried most of the settings and found for myself I preferred the Automatic Mode.
    The Pro's
    Cheap, Easy to install and makes a big difference in performance in a good way.
    The Con's
    It takes a little of getting used to and can make throttle response and cruising a bit jerky until you get used to it.
    Would I recommend? Yes
    (I haven't had any issues with the cars electronic system like I had with one of those not so cheap plug in's to the fuel pressure regulator ones. That one put the car into limp mode)
    04 L322 Vogue V8 - Work truck
    07 Freelander 2 TD4 SE - The wifes
    74 Leyland P76 Targa Florio - Aspen Green
    91 Kawasaki GPZ900R
    Previous LRs = 78IIa series - 81, 93, 95 RRC - D2V8
    Dec 2020
    Perth,Australia
    Lol so you flick it on when you take the Mrs FL for a run and off when you return it. It just adjusts throttle response ?
