Thread: Red motor manifold needed
    Mar 2017
    Hunter valley nsw
    Dear All,
    I'm just getting into re-enabling a recently acquired S2A 109 traytop with a 186. It was originally a 6 cylinder vehicle, so it hasn't been butchered to fit the 186. It's an old but very neat conversion using a Dellow adaptor, etc.
    After sitting for 20+ years the engine has fired up and runs well but I have cooling system issues in that all the hoses are hard (as expected, and easy to deal with), etc; the biggest issue is the heater hose spigots on the inlet manifold are cactus, rotted off, non-existent.
    So, I'm looking for an inlet manifold for a 186 specifically from a HT-HK-HG series Holden, any suggestion on where to look?
    Regards,
    joe
    australia
    Quote Originally Posted by Rocket88 View Post
    So, I'm looking for an inlet manifold for a 186 specifically from a HT-HK-HG series Holden, any suggestions on where to look?
    rare spares
    Russell Rovers
    Series I Parts Specialists
    russellrovers AT gmail.com
    Phone 0428732001
    Mar 2007
    Warwick Qld
    Try a Wanted to buy ad on Facebook Marketplace. There must be hundreds of them sitting in sheds around Oz.
    1999 Disco TD5 ("Bluey")
    1996 Disco 300 TDi ("Slo-Mo")
    May 2006
    Woolgoolga
    Just don't hook them up? All the red motors i had years ago i never hooked them up, but most had aftermarket manifolds for holleys and tripple carbs.
    St Helena,Melbourne
    1.13 MB
    Quote Originally Posted by Vern View Post
    Yep, I have a manifold that some moron cut the ends of the heater jacket off, I've bought a few holdens and none have had it hooked up.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Back down the hill.
    Look at Redline and Speco, the price of new may surprise you.
    Irymple, Victoria, Australia
    G'day Rocket,
    sounds like you have a good project there to play with and take up some of your time and hard earned cash.
    Be great to see some pics of the vehicle and a few of it under the hood, the Dellow conversion plate and engine mounts etc.
    Is it a Dellow Conversion that uses the Land Rover starter motor?
    Running it without the water heated manifold won't make much difference, might take a bit longer to run smooth from start up.
    Good luck with the project.
    Cheers, Mick.
    1974 S3 88 Holden 186.
    1971 S2A 88
    1972 S3 88 x 2
    1959 S2 88 ARN 111-014
    1959 S2 88 ARN 111-556
    REMLR 88
    1969 BSA Bantam B175
