Thread: Helicopter sling load
    May 2012
    Wannanup WA
    4.70 MB
    How to lift an air con, NOT:
    JDNSW's Avatar
    Reminds me of a similar incident with an ordinary size refrigerator when I was in PNG! (Fifty years ago)
    Mar 2007
    Warwick Qld
    Ex RAAF type told me once that the emergency dump switch is real touchy, and dropped loads are much more common than most people think.
    1999 Disco TD5 ("Bluey")
    1996 Disco 300 TDi ("Slo-Mo")
    May 2012
    Wannanup WA
    4.70 MB
    For anyone interested here is a video of the operation from the start.
    Nobody has come up with a reason for the drop, whether it was intentional or not. I have made a comment on another forum where I stated that the strop or slings, are WAY too short. A respected poster has come back and stated that because of local regulations and city ordnances, they are restricted to a certain radius with the load. It appears that they were lifting from a street intersection, but puting a big helicopter like that down amongst high rise buildings is a bit "iffy" to say the least! A longer strop gets the helicopter clear of crap like that.
    A longer strop also gives both better control of the helicopter, plus makes it a lot easier for the ground crew to "spot" the load, especially big heavy loads such as that being attempted.
    I am endorsed for sling loads and it is probably the most dangerous thing that you can attempt, even more so than mustering! It gives me the shivers just thinking about it.
    There are usually two emergency release options. One should be on the cyclic stick so it is not necessary to move you hand from the controls to operate it, and it is electrically operated. A second back up could be a foot pedal mechanical device or similar. Never flown them, but I believe that the Skycrane also has an explosive release as a back up.
    Sep 2010
    The Hills.
    152.79 MB
    Everyone kitted up in PPE, none of which would have saved them......
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
