Results 1 to 10 of 14
Thread: Can’t open the tailgate!
    Ringwood, Vic
    Never had this problem before today. Can’t open the tailgate!
    tried operating the remote several times, moved the car (thinking a bit of chassis twist might do it) and nope, it won’t open. I hear the mechanism doing it’s thing but it won’t open.
    any ideas?
    D4 SDV6, a blank canvas
    Oct 2016
    It’s a very common problem, the actuator (part # FUG500010) gets sluggish and needs to be replaced. It’s housed in the lower tailgate and is a pretty straight forward job once you have the upper tailgate open (Lots of videos on YouTube).
    D4 SDV6 MY16 HSE Corris Grey with Rhino Backbone Pioneer Tray, Traxide TBS, APT full Armadillo, Llams, Travall Barrier, 19" Cooper Zeon LTZ, Tow Pro Elite, UHF GME XRS-370C
    Mar 2018
    Hi
    I had the same problem on my D4. There are lots of links on here and the UK Disco forums with pics of how to pull the trim off the tailgate. It's not difficult once you get the tail gate down! I was lucky and eventually it did open for mey. Otherwise you have to get into the back of the car and cut into the trim. So keep trying and hopefully it will open.
    I got the tailgate actuator part number FUG500010 from Roverlord in Victoria. The part in 2018 was $101. I did the replacement myself which did save heaps compared to getting any dealer to do it. So you may as well order it tomorrow so you will have it!
    There are also some posts on here on how to add a wire trace to it so if the prob occurs again you have a manual backup method. I have not yet done that with mine. Cross fingers.
    Mike
    Oct 2011
    Fremantle WA
    Quote Originally Posted by wardy1 View Post
    any ideas?
    Waiting to get mine repaired.
    Have you tried using the fob unlock at the same time as you try to unlock the top section via the underside locking handle of the actual top section- works on mine as an interim step
    Oct 2016
    Quote Originally Posted by speleomike View Post
    If you can’t open the tailgate, you don’t need to cut into the trim. Inside the boot you just need to pry the lower tailgate carpeted section away from the hard plastic edge where the lower and upper tailgates meet. Best to use a plastic trim tool but a paint scrapper or flat screw driver would work. Numerous videos on YouTube showing how to do it.
    Ringwood, Vic
    Thanks guys. The new actuator is in transit..using the remote at the same time as pressing the lartch has worked so getting to it all should be ok
    thanks again to all
    Oct 2016
    thanks again to all
    I would highly recommend taking the carpet trim off while waiting for the new actuator to arrive. When the actuator starts to become sluggish it will open now and then for a short period of time then it suddenly won’t work at all. It is an easy job to get the lower tailgate open with the carpet trim removed but a real challenge with it on
    Wembus888 Guest
    Same issue, different problem
    I’ve just bought a 2008 D3, with the tailgate not opening. I found that the actuator sounded like it was working, but only the RHS would unlock, and not the LHS. I found all the YouTube self help videos, and all gave good pointers, but the best was an English bloke, who reminded me of a cross eyed John Malcovich. His was definitely the best, search powerfulukltd.
    However, after pulling the trim back, the problem turned out to be the tailgate LHS lower actuator P/N FUG500130. That required taking as many screws as possible off the internal circular panel, and squeezing my hand past. It’s apparently a rare fault, so much so, many spare parts dealers in Perth don’t stock it. I did source one ex East Coast thru Barbagello. I’m looking forward to getting it and putting the trim back together.
    One question though, has anyone else had the same defect, and if so, the little Johnson Electric motor inside that drives the actuary gear, do you have a part number, and is that little motor available to purchase separately?
    Mansfield, Victroria
    Quote Originally Posted by Wembus888 View Post
    Yes it’s a Ford Fiesta actuator
    Land Rover Discovery 3 4 Rear Trunk / Tailgate Actuator Fix for £10 ! LR3 LR4 - YouTube
    This looks like it
    Tailgate Central Lock Motor Actuator for Fiesta Mk6 Ford Fusion New 2S6T432A98AF | eBay
    Oct 2016
    That’s for the the upper tailgate (actuator housed in lower tailgate) but he’s talking about the two for the lower tailgate, specifically the LHS one
