Results 1 to 10 of 14
Thread: Closable Grill/Blind Thingy
    Yass NSW
    Does anyone know much about a manually controlled grill that can be clossed or opened? It would be meant for water crossings. I'm interested in trying to get one to keep my beaste happy through winter and the water crossings in the future.
    Is it a venetian blind type setup for a radiator grille?
    How would it protect the rest of the engine bay to water ingression i.e the big area around the engine block. To make it effective wouldn't you have to seal the rest of the engine bay as well? If you do that wouldn't you need bonnet vents to avoid extreme engine bay temperatures?
    Buy a tank it'd be easier
    Back in the early 60s I had a Renault 4CV. It had a holland blind in front of the radiator. I recall it was operated just like the holland blinds on has in a house.
    Ron
    Adelaide - Torrens Park
    Dobbo - For water crossings all you need to do is block the grille to prevent the mass of water going through the radiator. This serves two purpopses, firstly it helps stop the fan from being pulled forwards through the radiator and secondly, it helps build a bow wave in front of the vehicle.
    Quote Originally Posted by BigJon
    I realise this but deep water still has the potential to get into other areas, If your going to the extent of closing the grille why not seal the rest so deeper wading can be possible
    Quote Originally Posted by p38arover
    Ron
    That is rear engined with the air intakes just behind the rear doors! Which is not to say it doesn't have a blind in front of the radiator!
    Quote Originally Posted by George130
    Manually or thermostatically controlled shutters or blinds on the radiator have been common on radiators in cold climates since the 1920s at least, but are rarely seen in Australia since most Australians live in climates that are mild compared to a lot of places. Today they mostly take the form of radiator muffs, usually ones that clip on the outside of the grille. I remember when my brother lived in Copenhagen he had a Citroen Dyane, and commented that the radiator muff sold there had no apparent way of ANY air getting through other than leakage round the edges, where the one sold in France had a hole for the Citroen emblem in the middle.
    On the County I use a series of strips of the black plastic used for damp courses - they fit nicely down the spaces between the ribs on the back of the plastic grille, between it and the chaff guard. I leave the centre one uncovered, this provides plenty of cooling in winter, and speeds warm-up, always slow on the Isuzu engine because of its thermal mass, and helps the heater to work.
    Quote Originally Posted by JDNSW
    That's correct. The blind was in front of the radiator (behind the rear seat). I seem to recall the blind was mounted at the bottom and was pulled upward. Another pull released it to recoil (as can be expected from a holland blind).
    Ron
    Adelaide Hills. South Australia
    There was a bloke ("Rogue Trooper" ??) on LRA, (formerly LRE) or it may have been Offroaders Rant, who made quite a professional looking one using metal slats & iirc was operated by a quadrant of some sort. It really looked the business.
    I will see if I can contact him & let you know.
    Oct 2003
    Gold Coast, Qld.
    I know guys tie a tarp to the front when doing big river crossings but a nice in-cab operated shutter version would be great... thinking would be fantastic when doing bog runs also to help reduce the radiator front getting clogged with mud.... hmmm bring on the ideas!!!
    RAAF Tactical 200184 & 200168
