Thread: Tow Hitch Key
    Aug 2015
    melbourne
    Tow Hitch Key
    G'day chaps! We have a Disco 3 with tow hitch installed, but no key. Is there a way to get this off without the key? Or would I be best to go see a locksmith to get a key cut, if that's even a possibility?
    Thanks!
    Oct 2012
    Tow Hitch Key
    Quote Originally Posted by pastor098 View Post
    Thanks!
    If you look on the key barrel there will be a number. This is same key type as genuine LR roof racks if you have them.
    LR racks are Thule racks. If you go to a Thule roof rack shop they sell replacement keys quite cheaply.
    This may be one solution if numbers match.
    In my case I bought LR roof racks that had no key in the box. I had a huge set of keys for all the fly screens and windy windows on our house. They have similar barrels with numbers and I got lucky one of the key sets work on my roof racks.
    When I say ‘works’ it takes a little bit of jiggling and fussing compared to the exact key but good enough.
    Mar 2016
    North Lakes QLD
    Punch out the sping pin, remove green knob, put a nail or similar through hole and pull out and turn to remove hitch.
    You can buy new knobs with key for about $30 - $40. There are two different types make sure you get the right one.
    There is no eraser on the pencil of life.
    Now - Not a Land Rover (2018 Dmax)
    Was - 2008 D3 SE 4.0l V6
    Was - 2000 D2 TD5 with much fruit.
    Ray
    Apr 2010
    Northern Victoria
    tow hitch key
    PM sent
    Ivan
    2005 D3, 245/70/17 STmax, Tvan, Traxide, Mitch hitch
    Aug 2015
    melbourne
    Thanks fellas! Gives me something to work off, great!
    Just a massive PIA getting spare wheel off/on with the hitch in the way. Particularly now with a larger tyre on the rim.
    Cheers all!
    Sep 2014
    Baldivis WA
    When i bought my D4 it had no key for the green button on the tow hitch. Went to a local locksmith, they id'd, cut and gave me two keys within 20minutes, cost about 25 bucks. No need to destroy your tow hitch or use keys that "almost" fit.
    Jun 2020
    I bought a replacement key for my tow hitch off ebay. the only problem is it's not a folding key like the original so you cannot store it in the space designated for the tow hitch (in the 5 seater... I have no idea where it's stored in the 7 seater). but that's easily fixed...
    Land Rover & Range Rover Tow Bar Hitch Lock Keys Made To Code Number-1D1 - 1D57 | eBay
    Sep 2014
    Baldivis WA
    In the 7 seater it lives in the lh rear cubby hole (when standing at the tailgate looking into the car) in a special foam cutout.
    Jan 2020
    Terramungamine NSW
    While you have the hitch out, would be a good idea to give it a service (lots of info on the forum, some of it even correct), and smear a poofteenth of Neverseize goop over the wedge when you put it back, so you only need a small hammer to get it out next time. The other thing I recommend is using a D4 hitch, which is a bit shorter and actually lets you remove the spare tyre without adding too much to the blue haze.
    David
    Feb 2011
    Hobart, Tasmania, Australia
    I bought replacements for both our D4's that came without the keys from 1D Series Tow Bar Keys - Replacement Keys Ltd
