Results 1 to 10 of 15
Thread: Telstra Cel-fi Go issue
    Feb 2019
    Anyone have experience with Cel-Fi Go mobile booster?
    Mine is saying not receiving signal from network and has a blinking red led?
    Any advice would be much appreciated!
    "Vader" MY 2016 HSE, Black Pack, Toyo 265/50R20 AT2, Traxide Dual Battery kit
    Apr 2019
    Timely as I’m considering installing one for our upcoming trip.
    99.87 MB
    What aerials do you have? We run very directional double yagis and they're very sensitive to their direction being slightly off. It may be worth also just blowing out your connections.
    Slunnie
    Kallangur, Brisbane
    Quote Originally Posted by Birdboy View Post
    Have you had a look at the Wave App to see what it says?
    + 2016 D4 TDV6
    Feb 2019
    Quote Originally Posted by Milton477 View Post
    Yes it’s saying no signal from network. One of the list of fault options in the app says register it but I did that when I first bought it. Seemed to work for a couple of months ...
    Feb 2019
    It’s a GME aerial. Big black one - can’t remember model but here is a photo. Over a metre long
    Kallangur, Brisbane
    Mine shows a red light when the donor antenna is disconnected.
    + 2016 D4 TDV6
    Apr 2012
    Whyalla, SA
    Did you fit a new connector when you ran it through? Or just use the exiting one already on the coax?
    Grab a multimeter and do a test to ensure no break in the coax to antenna. Then test theres no continuity between line and ground.
    Next would be check all fittings on unit.
    Register again if required.
    Where is your internal antenna located?
    Feb 2019
    Thanks Tombie.
    I used existing connector when running through (all taped up to try not to damage it). How do you test continuity on the coax? (Sorry I'm not the greatest with a multi meter!)
    Won't seem to let me re-register. I did try uninstalling the app and reinstalling but still recognised unit. I'll have another look.
    Internal antenna not fixed yet. Was thinking at back of centre console but would love your thoughts on that - or where you have yours?
    Feb 2019
    Checked continuity of donor/external antenna and all good.
    Disconnected everything and reconnected in correct order and it worked for a few seconds before it started flashing green/yellow.
    Tried doing antenna position test again but still saying “no metric”.
    Maybe internal antenna not working??
