Results 1 to 3 of 3
Thread: 300Tdi starting issue
    Oct 2013
    Richmond, NSW
    Took the 300Tdi for a run last weekend. Stopped to go into Bunnings as you do (even though there is still no sausage sizzle) and then when I tried to restart 20 mins later it tried to turn over for a fraction of a second and then everything died... no dash lights, not even the radio... while sitting there considering options after around ten minutes the radio started again... all by itself. I have a Bluetooth battery monitoring app (BM2 I think) so I checked this and noticed the voltage was rising....
    As I watched the voltage kept rising so once it got to a sufficient level I tried starting and it fired first time.. I had the alternator and the battery checked and they were fine...
    I checked battery cable security and no issue.
    I have had no issues since then. Any ideas what might be the underlying problem?
    Cheers - Simon
    Travelrover
    Adventure before Dementia
    2012 Puma 90 - Black
    1999 Td5 110 Ute - White
    1996 Tdi 300 Wagon - White
    Aug 2012
    Logan,Queensland
    1. possibly a bad earth on the gearbox or the connection to the chassis.
    2. loose connection on the positive at the starter motor. This is where all the power comes from to supply the vehicle.
    '95 Defender 130 Single Cab
    HS2.8 TGV Powered
    98% of all Land Rovers built are still on the road.
    The other 2% made it home.
    Cost difference between Britpart and Genuine seals: £2.04. Knowing that your brakes won't fail at any moment: Priceless.
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by jboot51 View Post
    Indeed.
    Oh, and we have sausage sizzles in Vic now. Go figure.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
