Results 1 to 10 of 18
Thread: centre diff lock not engageing
    Gosford
    Any ideas peoples I have a 96.5 V8 Auto Disco and for some reason i can only select high and low range with the leaver, It will not move over to the left and will not illuminate the on dash indicator. I plan on looking at it this weekend but any sugestions as to the reason would be helpfull.
    Oz
    Might just be a build up of mud/crud on the linkage.
    You might be able to spray it from underneath the vehicle and free it up. If not the easiest way I found was to remove the centre console and then the auto shifter. That way you can see what you need to get to easily.
    Andrew
    May 2006
    Greenbank Brisbane, QLD
    Didn't mean to highjack this thread but do all Tdi's have centre diff locks and what do they do? This was edited after Bigjon. When you lock them what happens why is it different to not locking it are they 2 wheel drive when not locked?
    Adelaide - Torrens Park
    Yes they do. It locks the centre diff...
    May 2006
    Good one
    with lack of use or have never been used they can be tight - try engaging it when the car is moving every so slowly and I mean slowly and it might go in - but then it might not or the light might come on but as soon as you try to drove off you might have a big bunch of neutrals and a bang because it hasn't actually locked - practice make perfect
    Yass NSW
    My light is intermitent but it does engage. Are you certain its just the light not engaging? When looking at the lever you can't always tell.
    Jul 2003
    Quote Originally Posted by QSDT
    "Modern" Land Rovers are all wheel drives.
    The centre differential allows the front and rear axles to rotate at different "speeds" as the car goes around corners...the distances travelled by each of the wheels is different
    Without the CDL engaged the Series One Disco is an all wheel drive until one of the wheels looses traction and all the "drive" goes to the wheel that is spinning.
    When you engage the centre differential lock the front axle and the rear axle are locked together so when one of the wheels starts spinning half of the drive goes to the spinning wheel and the other half goes the axle whose the wheels have traction...so you can continue to drive.
    If the wheels on the front and rear axles loose traction and the wheels continue to spin you have a no wheel drive.
    Check this out:
    http://auto.howstuffworks.com/four-wheel-drive.htm
    Mahn England
    Ex 300Tdi Disco:
    Gosford
    Quote Originally Posted by George130
    I thought that might be the case also, but i have got absolutly no positive sideways movement of the diff lock leaver so i will have to take a good look at it on saturday.
    Cheers everyone for your help much apreciated
    Brisbane, Queensland
    I had the same problem on a LT95 box - could not move the gear stick side ways to engage the centre diff lock. It was as stated earlier just seized up from lack of use - mud and rust.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
