                                                15th February 2021, 09:33 PM
			10AS settings, Defender 2004 TD5
					Hi All,
 I'm hoping somebody may be able to assist me with 10AS settings for my Defender TD5 2004. I have a Nanocom Evo which has enabled me to do some setting up of the alarm/immobiliser, which for quite a few years has been "switched off". (Australian Defenders normally, as supplied, seem to have the 10AS programmed as a CDL controller only). I have 3 key remotes which are all programmed in to the 10AS & operative.
 As the vehicle is only used for normal on road purposes these days, I decided to activate the alarm/immobiliser, which was generally successful. I am finding that forum information, & also information on Blackbox Solutions for the 10AS is rather confusing, & I can't really find a way (if there is one?) to get the 10AS to do what I would ideally like.
 This is:
 1. Alarm/active immobiliser turned on when using the plip to lock.
 2. Alarm/active immobiliser turned on when using the key alone to lock (no plip), & turned off when unlocked with the key alone.
 3. Passive immobiliser not to activate when the vehicle is left unlocked for more than 30mins.
 4. In an emergency I would like to be able to use the EKA procedure to start the engine if it is in an immobilised state.
 I am aware that the ARM ON LOCK setting in the Nanocom controls whether the immobiliser activates, but it also seems to prevent the alarm as well, which is not what I want. It seems to be "all or nothing", & this is is what puzzles me.
 The current Nanocom 10AS settings for my vehicle are:
 Parameter VALUE
 Time Error NONE
 Comms SMART
 Interior Light SMART
 Welcome Light ENABLED
 Arm/Disarm Flash HAZARD
 Arm/Disarm Confirm HAZARD
 Arm on Lock ENABLED
 Resync on Arm ENABLED
 Relock ENABLED
 Mislock NOTED
 Mislock Noise ENABLED
 Resync on Lock ENABLED
 Plip Immobilize ENABLED
 Plip Relock DISABLED
 Key Mobilize ENABLED
 Passive Immobilize DISABLED
 Key Disarm ENABLED
 C.D.L. When ARM NONE
 Flash on Alarm HAZARD
 Alarm Sound PULSED
 Time Sync. USED
 Low Battery Error ENABLED
 Battery Error USE COUNT
 Tamper Warn YES
 Cat. Overheat DISABLED
 Mems Failure Indic. DISABLED
 Vehicle DEFENDER
 Immobilizer MEMS-TD5
 These are in most respects, quite acceptable, but I still find that when the vehicle is left unlocked (using the plip) for 30 mins or so, the passive immobiliser will still turn on, in spite of being disabled in the 10AS settings, necessitating use of the plip to mobilise the engine.
 Are you able to suggest any mods to the above settings to achieve the 1-4 requirements above? I am pretty sure the 10AS is working as designed, & I certainly have not had any starting problems at any stage.
 Any suggestions would be greatly appreciated.
 Lionel
