Thread: Lock-tabs, Loctite or Both?
    Jan 2017
    Gentlemen,
    Just wondering what the accumulated wisdom of this group is in regards to securing blots such as Fly wheel bolts?
    We have the old and tried lock tabs that get hammering into position so the head of the bolt cannot move. We have a range of thread locking formulations like Loc-tite or is it best to be super conservative and use both?
    Some of my Tabs are pretty beaten up and could well fail by simply breaking off. New one are not necessarily easy or cheap to find.
    Loctite is super convenient but is it enough for a Series 1 80" puttering around the urban streets of Perth?
    thanks in advance.
    Jeff
    Homestar's Avatar
    Aug 2010
    Sunbury, VIC
    If the locking tabs are borderline, I’d just go with Loctite 243 as I keep a bottle in the garage but if you think you want stronger then 263 would be the go IMO.
    I use both as my own preference.
    I'll do either if the customer has a preference.
    I wont reuse locktabs that have been folded prior without loctite.
    Nov 2008
    Bruthen, Eastern Vic.
    Quote Originally Posted by jedwards View Post
    Gentlemen,
    thanks in advance.
    Jeff
    If you anneal the tabs they have a better chance of surviving, but I'd still use Loctite on the bolts.
    Just because it's hard to get in there again to fix things that come loose.
    Terry
    80 109" 2.6 P ex Army GS, saved from the scrappie.
    95 300tdi 130 Single cab tray.
    2010 Guzzi 750
    Jan 2017
    Quote Originally Posted by rover-56 View Post
    Terry
    Good idea Terry,
    I'll heat them up and see how they turn out.
    I do like the idea using Loctite anyway, so happy to have that confirmed by this excellent and knowledgable group.
    regards
    Jeff
