Results 1 to 4 of 4
Thread: repair insulation layer on old solar HW tank?
    May 2006
    Yack
    2.78 MB
    The solar HW system is as old as the house so the writing may be on the wall - however it works very well and I would like to get a few more years out of it.
    The tank sits on the roof in the weather.
    It developed a rusty crack in the outer skin several years ago ( before we bought the house) and it is now about 2 feet long and no doubt lets the weather in and reduces its thermal efficiency. It exposes the insulation layer ( fibreglass?) to the sun and rain.
    What might be some options to repair it and keep the weather out?
    Ideas?
    thanks
    My third 98 D1 300tdi Auto -now registered
    81 Rover SD1 manual - long term project
    Nov 2008
    Mostly over there
    22.04 MB
    What is the condition of the water cylinder? Is it made of copper or stainless steel?
    Apr 2015
    Hervey Bay
    If it is just the outer sheet metal rusted away I'd use expander foam in a can to make up the insulation you might have lost and shape it to conform with the tank. Prep the sheet metal with sanding and rust converter. Then a couple of layers of fiberglass to seal it all back up again.
    (The Bositk Expanda foam is good for 90 degrees and the Sika Boom foam is good for 80 degrees. Should have enough temperature resistance for a hot water tank).
    04 L322 Vogue V8 - Work truck
    07 Freelander 2 TD4 SE - The wifes
    74 Leyland P76 Targa Florio - Aspen Green
    91 Kawasaki GPZ900R
    Previous LRs = 78IIa series - 81, 93, 95 RRC - D2V8
    Adelaide Hills. South Australia
    [QUOTE=edddo;3065218]The solar HW system is as old as the house so the writing may be on the wall - however it works very well and I would like to get a few more years out of it.
    Ideas?
    thanks
    IMHO that has the appearance of a Tank water leak inside the cladding so it may be that the rest of the Sheet metal cladding is knackered.
    Just a thought while looking at your images. I hope I am wrong.
    Maybe you could drill a small hole in it near the bottom & see if any water drips/pours out. NB. Be careful to use a very short drill bit though. If so it will need more checking as any sign of free water could still be rain that has entered over time.
