Results 1 to 10 of 13
Thread: D2 key fobs - where are you buying them from these days
    Geelong, VIC
    I searched and found some older threads, but nothing recent.
    Usual issue of rubber bits falling out of the key fob. I bought a couple of bare fobs from eBay last year but they were rubbish. Rubber was too hard to be able to actually make the switches inside work and the seals were a poor fit.
    Anyone have a current recommendation on where to buy something reasonable aftermarket, or is it one of those things where the only decent option is to go genuine?
    Steve
    1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
    1988 120 with rust and potential
    1999 300tdi 130 single cab - "stock as bro"
    2003 D2a Td5 - the boss's daily drive
    Aug 2011
    North Coast NSW
    Quote Originally Posted by steveG View Post
    Steve
    This one not too bad For Land Rover Range Rover Discovery TD5 V8 2 Button Remote Key Case Shell/Case | eBay
    Geelong, VIC
    Thanks Tommo - I'll have a crack at one of those for a start.
    If anyone else has a different recommendation I'm still keen to hear.
    Steve
    Sep 2010
    The Hills.
    152.79 MB
    I tried a couple, and they were rubbish. Are they ALL rubbish? Possibly not, I don't know. But I chose instead to buy one of these. They don't say Land Rover, but they DO say Valeo. Get it cut, or swap the blade, and then all you need is a Nanocom.
    LAND ROVER Key Discovery 2 Key complete Remote Key Ready for programming 433mhz | eBay
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Jan 2011
    Gippsland
    Steve
    I got mine from Karcraft Australia.
    Okay, it did cost a tad more than the common ebay offerings... but hey! you get what you pay for don't you.
    I've had it 8 or 9 years ago now ,and it's still working perfectly
    LROCV member #131
    1999 build D2 TD5 Auto, Mantec snorkel, 2" LRA spring lift, ARB on board air, Ashcroft ATB, CMM air ram CDL shifter, swag & gold pans ....
    Geelong, VIC
    Arrived today. Quality seems pretty good. Says Valeo on the back - but who knows...
    The transponder bit from my old key clipped on nicely and the buttons work fine.
    Not sure if the black tape over the unlock button is meant to be removed but since the buttons work with it on I’ll leave it there to fall off by itself.
    Steve
    Sep 2010
    The Hills.
    152.79 MB
    Steve
    Looks real enough. Pull the tape off. Who knows, it might say MG, or Jaguar, or Aston Martin. Valeo are the OEM for these. If it's 433Hz and it works then good news.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    99.87 MB
    I also just bought a blank empty Valeo fob from ebay. You can swap the electronics and the blade across.
    Slunnie
    Back down the hill.
    What's the trick with the blade? I have one that is loose.
    Aug 2011
    North Coast NSW
    Quote Originally Posted by Tins View Post
    Says Land Rover under the tape
