Results 1 to 4 of 4
Thread: IIDTool wont clear suspension inactive fault
    Oct 2010
    Carindale, Brisbane, Qld
    I have got an EAS Suspension Inactive fault on the dash, but my IIDTool BT cannot see any suspension faults. Anybody had this? How do I clear it?
    I have tried a second phone also. And checked all the pins and wiring to the ODBII port. Other faults can be read and cleared OK.
    2005 L322 Vogue 4.4 M62TU
    Now: 2005 L322 Vogue 4.4 M62TU (Black)
    Before: 2000 P38A HSE 4.6 - stately capability | 2008 Kluger KX-S | 2004 Forester | 2000 Yamaha XJR1300 | 1993 VR Calais | 1974 HQ Statesman - 308 V8 | HT | HK
    Have you turned the steering wheel fully lock to lock?
    Yes, I know it seems odd but that is often required.
    Aug 2020
    What fault code is it? Is the abs unit also generating a fault? (They are related, even if you clear abs it can still retrigger on EAS
    Oct 2010
    FIXED
    FIXED
    I unplugged the AV boxes in the back, which were causing CAN bus fault, now the IID Tool can connect to the EAS CPU.
