Page 1 of 8 123 ... LastLast
Results 1 to 10 of 75
Thread: Slunnie's enclosed trailer build
    99.87 MB
    Because everybody loves a trailer build.
    I havent built one for a while, so here we go. Hopefully I don't regret posting this up.
    This is the old banger, it is an enclosed karting trailer and built as lightly as possible for a fairly lightweight load, but it is such an amazingly useful and handy trailer. An oldie but a goodie!
    These days however the enclosed trailer gets used for heavier duty work such as lugging fencing gear, engines and gearboxes, firewood etc. I want to design and make a replacement trailer so that it can be that elusive trailer that can do everything, well as best as possible.
    The trailer needs to have heavier load rating, it needs to have a stronger floor, it needs to be able to tie down loads in the load space, it needs to be able to better accept loading by engine crane with roof clearance, it needs to be able to receive loads from ANL , I would like it to not leak water (not that the old one does) and I would like the 2 side swing doors to be better designed for usability.
    Day 1
    So, here it starts. The chassis is 50x50x4 RHS. I always run heavy wall main chassis rails to ensure suspension points are secure and don't require plating, they are the keystone to a good trailer and I hate it when trailers skimp in this area. The trailer spec is 1500kg, and I would almost always run a 75x50 chassis for that load rating, but this trailer is pretty short it will be well supported by the drawbar and suspension points. The cross members are spaced at 400's, so the trailer is 2 sheets long at about 2470mm iirc long and so the floor is well supported. The chassis has been cut, assembled, squared, tacked, checked, top and bottom welds.
    Slunnie
    Aug 2010
    Sunbury, VIC
    Great, I do like a good trailer build thread.
    As to you regretting it - stay tuned, the experts will surely tell you how to do what you already know how to.
    It’s one of the reasons I stopped posting on some of my threads - got more comments like ‘you should do this’ or ‘This is how you do it’ even though I wasn’t asking for advice and had been doing what I was posting for years and really just trying to put something up others would be interested in.
    Hope this doesn’t go that way, I’m happy to sit back and watch your progress. Slunnie's enclosed trailer build
    Mar 2016
    Adelaide
    Looking forward to following along
    "Land Rover - making mechanics out of everyday motorists for nearly 70 years"
    99.87 MB
    Quote Originally Posted by Homestar View Post
    You're on the money, I bracing myself for it!
    Hopefully it is seen as a good build.
    Slunnie
    99.87 MB
    Chassis is fully welded with fillets. Suspension points are added and welded in. These are 1500kg slipper springs, simple and effective. The axle is a 45mm square, when running 4WD tyres as I rule of thumb I go straight to 45mm irrespective of load rating for strength. Brakes are over-ride, cable operated disc brakes. Slimline bearings and Landcruiser 6 stud hubs running hilux wheels. The axle length was specified for these hilux splitties with 50mm tyre clearance to chassis on each side, but it looks like there may be more than that (did I add 50mm/side and the supplier do the same???). I've got some 17" Hilux steelies that may bring the clearances in a bit, will check it out a little later. The axle is in a SOA arrangement rather than a conventional setup, this is to bring the trailer ride height up higher. The normal tow vehicle is my Disco2 which sits about 6-7" higher than standard, so having the trailer axle setup like this actually levels it out. Drawbar has been added, this is made from 75x50x4 with a clearance to the body of 1350mm. The coupling plate is on but obscured. I've done this a little differently also, rather than overhanging the plate so the front bolts are off the end of the drawbar, this time I have shifted the coupling plate a little further rearward and I will drill out the top of the drawbar so the couplings front bolts go through the coupling plate and through the top of the drawbar. It looks a bit tidier, see how it goes... I'm sure I'll find out why we don't normally do it that way shortly. Trailer is ready to flip onto its wheels, my Yr12 are really handy for this!
    Oh, just looking at the welder, we run a fleet of these WIA 270C Mig welders. I cant speak more highly of them. The cabinets are really intelligently designed, they know what fails and why and have designed for it. eg, drop down lids. These are transformer rather than inverter, so they are heavy but should also have longevity. The welder is very forgiving and great for people learning to weld while at the same time they have a lot of grunt, the settings can be off a little bit and a good weld can still be put down. The students have about 3 base settings and almost all work is done on those settings. We run 0.8mm wire for flexability between thin 1.6mm welding and chassis etc up to about 5-6mm and the odd bit of 10-12mm plate. We run about 10-15l/min gas flow rate with Argoshield light. With a 270A gun we melt very few contact tips these days. I'd recommend these, they do run on 15amp but for heavier work over 6mm need 20amp single phase.
    You can see below how the spring over axle arrangement levels the trailer behind my Disco2.
    Slunnie
    Apr 2017
    Maitland (ish) NSW
    We run Fronius in our workshop (spoilt I know) but they are the bees knees and are built for the tasks we do
    18 months old and over 1100 hrs of arc time so far with know faults as yet
    Discovery D2a 2004 TD5 auto (current)
    Discovery 1 V8 1996 manual (gone)
    Various series Land Rovers before moving to OZ
    99.87 MB
    Quote Originally Posted by Bluetoes View Post
    Thats good going! These WIA units are now 5 years old, no idea re arc time, but will check out the Fronius also when they get turned over.
    Slunnie
    NSW SW Slopes
    I assume the coupling plate is underneath the drawbar and that the bolts through the top of the drawbar are the bolt heads so that you're not clamping an air gap.
    99.87 MB
    In that picture with the trailer upside down so you can't see the coupling plate, but when the trailer is flipped onto it's wheels the coupling plate will sit on top of the drawbar. I'll just drill through the top of the drawbar only and then instead of couplings bolts only going into the coupling plate, they will also go through the top of the drawbar and I'll just fit the nuts from inside the drawbar... assuming all goes well! There won't be any air gap with the bolting though, if I went all the way through the drawbar it would need crush tubes also, but I dont think I need to go that far with it.
    Slunnie
    Sep 2010
    The Hills.
    152.79 MB
    Can't wait to tell you how to build your train set, Gav... Has to be next...
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
