I'm rather sure that it doesn't exist on the 1st RRS version, only on the L494, L405 RR etc
BTW, the vehicle model should be L320 - L322 is the MY02-12 Range Rover.
Hi all,
Recent purchaser of a 2013 RRS (previously had a D3) and for the life of me I can't find the grey electric brake module in the drivers side footwell. I have contorted myself to look and pulled on every cable but I just can't see it. I have looked through all the posts so I do see where it is meant to be but I am wondering if it does in fact exist in this model!
Thanks!
 Swaggie
						Swaggie
Moved to L320 RRS
Edit: sorry didn't read the post properly didn't see it was the electric brakes.
The wife's 07 Freelander 2 has a Trailer module behind the rear left panel in the cargo area so I would think a RRS would have a module as well. AS LONG AS it was fitted from the factory with the tow kit. If its an aftermarket tow hitch they might have just tapped into your light harness without fitting the module.
04 L322 Vogue V8 - Work truck
07 Freelander 2 TD4 SE - The wifes
74 Leyland P76 Targa Florio - Aspen Green
91 Kawasaki GPZ900R
Previous LRs = 78IIa series - 81, 93, 95 RRC - D2V8
 Swaggie
						Swaggie
						D3s, D4s and L320 RRS don't use a trailer module.
 Fossicker
						Fossicker
						I just installed a RedArc and connected from battery directly with a relay kit from Jaycar, and drilled the RedArc controller in the light switch as its easy to get out...
