Thread: Security light on
    Sep 2010
    The Hills.
    152.79 MB
    Security light on
    I can't remember if my car was doing this before. When I turn it on with the key the security light comes on, solid. I have to press the unlock button on the fob before it will start. seems to happen most times after I shut it off. As I no longer have a Nanocom I don't know what's what. I suppose it's a Nanocom thing to fix?
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Apr 2016
    Country Vic.
    You may or may not know .. but battery condition is vital on a D2(compared to a D1, at least) to minimise security system issues.
    I think this is common on all modern vehicles too tho .. my neighbours had the same issue with a small Mazda they own .. car sat a long time during lockdown, wouldn't unlock, then 'super locked itself' in their driveway.
    At least in a D2 you can manually open the door with key, even it if may result in loud sounds from a blaring horn! ... with the Mazda, you don't get this luxury!
    Before you examine the wonderland of security electrickery, be sure your battery is in very good to brand new condition, and not losing any charge .. then, if you still have issues investigate security system issues.
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
    Bacchus Marsh Vic.
    How old are the fob batteries? Been a while but I recall the light staying is a low fob voltage warning.
    Cheers, Kyle
    The Good Oil.
    When did you last visit?
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by AK83 View Post
    Batt is brand new.
    The "wonderland of security electrickery" is pretty scary.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by alien View Post
    Keys were new 2 years ago, but I'll change the batteries anyway.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Jul 2014
    west of Transylvania
    The red LED will just flash when the battery in the fob is low if that's the setting in the BCU. If the LED stays on solid means the vehicle is immobilised and if you can override that with an unlock command the problem is with the passive immobiliser which should be disabled when you turn ignition on. If this happens with both fobs and they are D2 fobs not Rover 75 ones(which are the same from outside) then the problem is with the passive remobilisation exciter coil which doesnt react to the fob but unlocking with fob remobilises the vehicle for 30 seconds
    Passive coil
    The passive coil is located around the ignition key barrel. When the BCU detects that the ignition key has been turned
    to the crank position, the vehicle's immobilisation system is activated and a signal is sent to the passive coil at a
    frequency of 125 kHz. The magnetic field generated in the coil is induced in the remote transmitter to trigger a remobilisation
    signal
    The BCU controls the passive remobilisation exciter coil (located around the ignition barrel) to generate a magneticfield which causes the handset to transmit a remobilisation signal. The BCU receives the signal and allows the vehicle
    to be started. If a valid signal from the handset is not received within one minute of the ignition being switched to
    position II, the BCU stops the passive coil from generating the magnetic field.
    Nov 2018
    Men, my td5 has exactly the same "feature". I got it from previous owner who said it was like that from the previous owner. I never mind it but good to learn more and if anything we can fix it that's good too.
    PS: my correct comment into the correct topic now.
