Results 1 to 10 of 19
Thread: Used Denso or New aftermarket starter motor?
    Nov 2018
    Hi all, make it short, I enjoyed the 1st bump start last night 30kms away from home with my D2a and successfully drove her home and dead on driveway now waiting for a new starter motor. Good point is I now know that my D2a is sooo very easy to do bump start.
    My question is which way to go? A Used Denso (which I will replace all new parts for the solenoid as I already bought one) or buy New aftermarket starter motor without brands?
    Thanks for giving me your thoughts.
    Back down the hill.
    Denso, I've been down the aftermarket track and returned to the same as you're considering, s/h Denso.
    Jan 2017
    Geraldton WA
    Why not simply refurbish the one you already have in the D2
    4.6m Quintrex boat
    Nov 2018
    Thanks for that. It happened the same on my MAF, trying an aftermarket MAF and it died in 1 day. Then pocket a VDO and very happy since then.
    Nov 2018
    I need the car back on road ASAP, and I can't see this is possible and it is expensive to rebuild the starter motor too I believe
    Quote Originally Posted by trout1105 View Post
    Jan 2017
    Geraldton WA
    Quote Originally Posted by maxperformance View Post
    Quite a simple job to replace the brushes, solenoid and the bearings which you should be able to do yourself and not that expensive either.
    The biggest job is getting the starter out and back in again which you will have to do regardless of what you decide to either replace or repair the starter.
    If you decide to use a second hand starter then there is no guarantee that that one won't die on you as well.
    4.6m Quintrex boat
    Mandurah WA
    Check the solenoid contacts before fitting the 2nd hand starter.If worn replace with For Land Rover Discovery Defender TD5 2.5 Diesel Starter Motor Repair Fix Kit AU | eBay Ensure full contact is made before tightening the posts.
    Nov 2014
    Nirvana near Albany W.A.
    seeing you already have the repair kit, it'll take you 5-10 minutes with it on the bench to fit, even if you just replace the contacts it will be years before you will have to do brushes, bearings etc.
    I'm seeing them last 2-3 sets of contacts before having to do brushes and bearings.
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    Ashdown and Ingram auto electric wholesalers have the parts you need to replace the solenoid parts, some kits on ebay are are not exact fit on the plunger diameter, they are close but not purpose built for the model starter.
    Sep 2010
    The Hills.
    152.79 MB
    Once more with feeling.....
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
